Did you follow the instructions to install the Smooth Stepper on your computer?
If you have, then okay. Turn off the Plug and Play system. Start Mach 3. Does it through a communication error for the ESS?
Fella's
I have another newbie question. I finally got everything wired up and installed on the Saturn 1 setup. I was able to connect to the smoothstepper from the computer, I loaded the pre made XML configs for one of the CRP 4x4 "pro" kits into Mach3. I can get the display window and the DRO's to jog in Mach3 but there is no motor movement on any of the steppers.
I checked the emergency stop and the "motor control" toggle on the enclosure. I checked that none of the limit switches were triggering manually by holding metal up to each and seeing each clear. I am able to connect to and ping the smoothstepper.
I am sure this is something simple that I am missing. any ideas on what to check next? I put in a request to CNC Router parts, but no one called me all day today.
Thank you for your help.
- Swap Mach 3/ESS for UCCNC/UC300ETH-5LPT on CRP PRO with Plug and Play Electronics
- Video PRO CNC Build Series: Plug and Play Electronics and Spindle Connection Guide
- 4x8 CNC Plasma Cutting Table with Electronics Nema 23 420 Oz-in motors, Plug & Play - No Longer Available
- Ethernet Smoothstepper Setup question with CNC RP plug and play
- CNC kit ?(Plug n' Play)
Lee
Yes I followed instructions. I can see the smoothstepper is up and running. In mach3 in the settings for the smoothstepper. I can see the checkboxes check and uncheck when I trigger the limit sensors. So I think the smoothstepper and Mach3 are talking fine.
Also. To answer you question: yes when the electronics are turned off I get an error that mach3 can’t find smoothstepper.
Well the hard work is done.
Pretty sure CRP has closed for the Holidays.
I sent a couple emails that have not been answered yet either. I would imagine they will open up full time today. They are on the left coast somewhere, so a few hours behind us.
I think there is a diagnostics page for the ESS. Look up top under plug in config.
Lee
By "motor control" are you referring to the Motor Enable switch on the main panel?
Excellent.
Lee
