New Machine Build Saturn 2 - 4x4 - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
Thread: Saturn 2 - 4x4
  1. #21
    Oct 2016
    Default Re: Saturn 2 - 4x4
    Quote Originally Posted by liqdfire View Post
    I used it last weekend to do a little test cut. It worked great, my only thought was that the 4 inch hose going directly to my dust collector had so much suction it was pulling the 3 inch long bristles into the vac port, lol
    There was absolutely no dust left on the machine though!
    I bit the bullet and purchased the KentCNC dust shoe. (works great) Similar to the CNCRP design. They place a 1" - 1.5" brush inside the main brush in some sections to keep it from getting sucked into the cutter or the hose.
    -Robert
  2. #22
    Jan 2006
    Finally got around to mounting the base board, I ordered a sheet of 5ft wide MDF from a local plywood supplier, only cost me $42.
    I laid out the grid pattern with a chalk line and drilled them with a forstner bit.
    Saturn 2 - 4x4-2017-12-02-15-30-18-jpg
    I miss calculated the last row by 1/4 inch, so they do not get bolts.
    Saturn 2 - 4x4-2017-12-02-17-17-00-jpg
    Saturn 2 - 4x4-2017-12-02-17-24-38-jpg
  3. #23
    Community Moderator difalkner's Avatar
    Nov 2014
    That looks really good. The missing bolts probably won't matter. I like the green theme!
    David
    David
    Romans 3:23
    CurlyWoodShop - www.etsy.com/shop/CurlyWoodShop
    David Falkner - www.youtube.com/user/difalkner
    difalkner - www.instagram.com/difalkner
Saturn 2 - 4x4
Saturn 2 - 4x4
