Need Help! accuracy issues over x axis - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
Thread: accuracy issues over x axis
  1. #21
    Community Moderator difalkner's Avatar
    Nov 2014
    Default Re: accuracy issues over x axis
    For those of us who are more visual, can you post a photo of your machine and where these pieces are that you're cutting?
    David
    David
    Romans 3:23
    CurlyWoodShop - www.etsy.com/shop/CurlyWoodShop
    David Falkner - www.youtube.com/user/difalkner
    difalkner - www.instagram.com/difalkner
  2. #22
    Jan 2014
    Quote Originally Posted by difalkner View Post
    David
    Sure, other things to note yesterday installed new pinion gear, and swapped racks with X and nothing has changed. Another thing I noticed is that one or both of the racks I had off had a decent bow in it I could mesh the teeth on both and rock them back and forth. How tight are most of you tightening down the pinion gear? Mine has always been relatively tight because if I don't crank them down I can push the Z axis a very small amount with the motors on and engaged. I'm still wondering if racks may be the issue, but before dumping more money at it, I'd like to know if anyone else has suggestions.
    Sent from my Nexus 6P using Tapatalk
  3. #23
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    I don't see how it could be the racks.
    It could be 100 different things, but I think it's a mechanical issue causing it, that you're not seeing. I don't think throwing money at it will solve it, but you never know.
    The fact that you see the same thing in Mach3 and UCCNC almost surely means it's mechanical.
    Unless it's your g-code??
    UCCNC 2017 Screenset
  4. #24
    Nov 2014
    Photos help, at least for me. Out of curiosity, since the X cut is parallel to the X axis, or appears it should be, when it is making the cut then Y shouldn't be moving at all. Since these are long cuts can you watch the Y motors and see if they move at all? They should be stationary. You won't even have to be cutting material to find out, just put the bit an inch above the surface and run it dry. It sounds like it's mechanical, as Gerry said, but I would want to rule out that one motor isn't somehow moving during the cut.
    David
    David
    Romans 3:23
  5. #25
    Mar 2003
    Shelby Township
    Put a V bit in there, and make two grooves the length of the table, one at each side of the gantry. Watch the DRO and make sure it's not changing during the cuts.
    The two grooves should be parallel over their entire length.
  6. #26
    Jan 2014
    Yup I am assuming mechanical too I have tested with and without gcode with the MDI and can still verify the error. I'll be in the shop tonight to test a couple more things.
  7. #27
    Jan 2014
    Quote Originally Posted by ger21 View Post
    I'll try that tonight too
  8. #28
    Apr 2008
    Should you post your g-code to rule that out?
    I had issues in the past with my pinions slipping...I drilled through the pinion and the shaft and secured them with a spring pin
    Sent from my SM-G900V using Tapatalk
  9. #29
    Jan 2014
    Here's the gcode I've been using on the tests
    profileTestingX.zip
  10. #30
    Jan 2014
    Ok bear with me spent all ####### weekend on this, I think I have figured it out. It started with me just out of a hunch measuring how far the z axis actually moved on top of the extrusion, which is what I used to have it calibrated to when I build the machine and guess what over the length of my calibration I was a 1/16th short. So I re-calibrated from the top of the extrusion not from the table with a vbit. Checked square in middle of table and I'm basically spot on square. I took my digital angle gauge along the top rail and somewhere in the middle range the steel rail bows down at first then back up again, and continues upward (also put a straight edge on it to verify). Basically I start going out of tram somewhere after the midpoint and it escalates over the rest of the length. Also it explains why I usually have ridges on my spoilboard after surfacing only on the right side of the table. I'm going to assume this is the problem since I have tested almost every suggestion and idea I could think of.
    accuracy issues over x axis-img_20170904_174227-jpg
    accuracy issues over x axis-img_20170904_174123-jpg
  11. #31
    Apr 2008
    accuracy issues over x axis-ce6b065a6746ce45977e4114a451a2ab-cnc-software-cnc-parts-jpg like this but mounted on the x axis and indicator on the smooth side of the rack. Sorry it took so long ot respond
  12. #32
    Apr 2008
    then run yor x axis far left and far right to see how far out your rack is out of alignment.
  13. #33
    Jan 2014
    Quote Originally Posted by davy182 View Post
    Ok that makes sense, I think I will try that on all my Axis. I'm pretty confident it's the x axis rail causing my problems, but when I swapped racks they do have a bow to them as well.
  14. #34
    Jan 2014
    Quick update, got the new rails from CRP, installed them last night. Then over my lunch break ran home to test another cut and it seems the problem is fixed. Both parts seemed to match and line up. I will continue to test and verify with the larger project. But I wanted to thank all of you for the suggestions, and helping me narrow this down.
