Need Help! greasing ballnut on Saturn
Results 1 to 4 of 4
Thread: greasing ballnut on Saturn
    Feb 2009
    Default greasing ballnut on Saturn
    Anyone figured out how to properly grease the ballnut on the Saturn z axis?
    Community Moderator difalkner's Avatar
    Nov 2014
    Default Re: greasing ballnut on Saturn
    I use the same NLGI #2 grease that I use on the rack and pinion and linear bearings. I take the excess grease from the linear bearings and wipe it on the ballscrew with a gloved hand (Nitrile or vinyl). That seems to work just fine. After it begins to pile up at the top and bottom I take a Starbucks stir stick (or any small piece of wood) and redistribute it on the ballscrew.
    David
    David
    Romans 3:23
    CurlyWoodShop - www.etsy.com/shop/CurlyWoodShop
    David Falkner - www.youtube.com/user/difalkner
    difalkner - www.instagram.com/difalkner
    Mar 2012
    How often are you greasing things? Wish there was some kind of a manual that came with the machine.
    Dave
    Nov 2014
    Seems like Nate told me to lube the linear bearings every 200 hours of operation. He said a good test is to wipe the rails with a clean white cloth and if you see grease then you're good, if not then it's time to lubricate. I've been doing a full lubrication of everything I can see on the machine about every 6 weeks or so depending on how often I've been using it.
    I'm on two really large woodworking projects right now, at least large for me, and only about 10% of it is on the CNC so it's been idle quite a bit over the last month or so. In about two weeks I'll be running the CNC a lot so I'll give it a good check-up before I plunge in.
    David
    David
    Romans 3:23
