Your machine got picked up today and FedEx said 4 days for delivery.====================
Nate at Fineline Automation tells me the machine shipped out yesterday so I am hoping to receive it by the end of the week. I ordered the machine Friday and it ships on the following Tuesday after changing the Nema 23 motor mounts to Nema 34 motor mounts...Can't beat that. Thanks Nate. I am definitely looking forward to receiving it. Now all I have to do is build a table, buy motors and electronics, wire the machine etc, etc, etc.
I have an old steel military table, built in the 50's, that would have been perfect for this machine...very heavy solid steel etc...but it was not wide enough or long enough so I will be building a new table specific for this machine. I will probably buy some 2" square tubing with a 1/8" wall thickness and weld up a good sturdy table over the weekend. Believe it or not but here in Arizona steel is pretty cheap. Wood prices seem to keep going up but the price of steel seems to be pretty constant. If David sees this post maybe he can comment on the table he built from wood. It looks pretty impressive and I have been wondering how it is performing. Is it as sturdy as you had hoped it would be?
I have settled on the 906 oz-in motors (KL34H295-43-8A) from Automation Technology. I have been comparing the 640 oz-in motor Gerry suggested to both the 906 oz-in and the 1200 oz-in motors and the 906 oz-in motor maintains more torque at pretty much any rpm than any of the other motors. I would never have guessed that to be true but Gerry is correct when he states "bigger is not always better". Thanks Gerry...your comments caused me to spend a lot more time and care researching and choosing the motors and I think I will be much better off in the long run. Also, the 906 oz-in motor has a pretty low inductance of 3.3 mH so it should also run pretty fast. The smaller 640 oz-in motor has an inductance of 2.1 mH which is better but since the 906 oz-in motor maintains higher torque than the 640 oz-in motor I decided to go with that one.
As far as motor drivers and power supplies goes I am still thinking about that. I definitely want to run the motors pretty close to their rated amperage, which is 6.1 amps, so I am thinking of providing each driver with it's own power supply...which is what Nate at Fineline Automation suggests. The problem is those power supplies are $110.00 each and if I am going to spend that kind of money I might as well go with one of the 4 axis Gecko setups which have the power supplies built in. That might cost me a little more money but I will end up with good quality drives and also save a lot of time without having to build a box and wiring everything not to mention the likely troubleshooting I will need to do. Any suggestions here would be welcome.
Again...thanks to everyone out there for letting me tap into your experience and knowledge.
More to come.........
Regarding the supplies: I would run 2 motors per 60V/10A supply. That's 2 supplies.
What motion control board are you using? The Ethernet Smoothstepper is a good choice.
