Results 1 to 3 of 3
Thread: Z Level rough with multipule rough tools
    mbi
    mbi is offline
    Apr 2008
    I was wondering if anyone has any suggestions when it comes to roughing large time consuming profiles such as mold surfaces. I use "Z level rough" and "multiple roughing tools" most of the time. As you probably already know, FeatureCam starts with the larger tool and works down to the smaller tool. FeatureCam seems to produce a lot of unnecessary passes within this strategy which in turn wastes time. Anyone have any ideas on how to cut down on some of the wasted time?
    Oct 2005
    I did a graphite trode a while back aprox. 10"x5" 2" thick lots of drafted sides and fins. On a boss part I will sometimes use parallel with a 1" index mill, makes quick work of extra material. It will remove a ton of material in a hurry without killing tooling. I never use the 1,2,3 section. I rough out a cavity with z level leaving .050 then a series of finishing with line tolerance around .001-.005. Then shine it up with the finer settings.
    What I mean is I do a single rough hit then only select certain surfaces to do a semi-finish with more aggressive feedrate and stepover. For me it is easier to program doing it this way. Because once you get a certain strategy to how your going to do it, all you have to do is copy and paste. Then turn the same semi-finish into a finish. This works well and doesn't cut a bunch of air.
    Last edited by Janos; 02-26-2010 at 06:47 AM. Reason: Had to clarify what I meant.
    Feb 2010
    g
  1. Replies: 3
    Last Post: 01-08-2009, 07:38 AM
  2. Rough Movement
    By dafowfidy in forum Mach Mill
    Last Post: 06-04-2008, 09:06 PM
  3. Rough Movement
    By jhwatts in forum Xylotex
    Last Post: 09-28-2006, 04:07 PM
  4. Rough Cut of a thread
    By Slythar in forum Test Forum
    Last Post: 04-09-2006, 09:00 PM
  5. truemill and z-rough and srm
    By championp in forum Surfcam
    Last Post: 02-22-2006, 10:51 PM
