Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > FeatureCAM CAD/CAM
FeatureCAM CAD/CAM Discuss FeatureCAM CAD/CAM software here.
Old 11-17-2009, 01:20 PM
Janos is on a distinguished road
3D Surface milling problem
I have a small triangular compound angle that should be easy enough to do. I can't get it to recognize the boundries or surfaces because it isn't in a standard UCS.
Old 11-17-2009, 09:17 PM
mbi mbi is offline
mbi is on a distinguished road
Align your ucs to the surface you want to machine. Use curve from surface and use surface edges. create a curve around the feature and use that curve as a stock boundary.
Old 11-18-2009, 07:31 AM
Thanks for the tip, I'll let you know how it goes.
Janos
Bad surface finish with 3-D milling dylskee Haas Mills 44 06-14-2007 06:09 PM
3D Milling Surface Finish Problem TurboME General Metalwork Discussion 15 12-17-2006 10:32 PM
Surface finish after milling a mold ? Shizzlemah Moldmaking 1 11-24-2006 08:31 PM
Surface Milling camtd EdgeCam 6 10-20-2006 12:08 AM
Surface Milling help needed Jcadwell General CAM Discussion 11 04-05-2004 12:23 AM
