The very first thing is to make sure your "stock axis" and your "rotating axis" are lined up together. Look under "view", then "show" to get your stock axis to show up. This HAS TO BE the same as your UCS to even get started. The help secton for 4th axis index or wrapping will help after that. Come back here if you get "stuck".
LinkBack URL
About LinkBacks
