Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > FeatureCAM CAD/CAM
FeatureCAM CAD/CAM Discuss FeatureCAM CAD/CAM software here.
Old 08-01-2009, 04:09 PM
Big Daddy is on a distinguished road
Having a problem Uninstalling and re-installing FeatureCam
A little help please! I’m having an issue with my FeatureCam so I decided the best thing I could do was to uninstall all versions of FeatureCam in my system/ clear my registry, then reinstall from scratch. Something just isn’t right with it in my new 10 ½ gig Quad core. It’s like something else has gotten a hold of the software and its limiting or should I say “disallowing” some of the more advanced capabilities FeatureCam offers. But after I do a complete uninstall then reinstall I end up with the very same limited features as I had before uninstalling. But my reinstall isn’t going clean either I get a error window popping up at the end of the install saying; ERROR. Turn off my UninstallWizard. But to the best of my knowledge I don’t have a UninstallWizard protecting my computer.
Also I’m running the very same load off the very same disc in my 3.2 gig computer in my shipping office and it doesn’t show or have any of these problems. zero/ZIP!
Any Ideas? All help will be appreciated.
Thanks.
Old 09-23-2009, 07:43 PM
2alpha is on a distinguished road
FCAM help
Prior to Ver 2010 ( Not yet released ) FeatureCAM does not support multicore PCs, it only uses one processor.
If you look at simulation settings you can see the products you are licensed for.
If it's not correct try reloading the PAF file if you have a backup copy, or if you have been paying the maint fees contact your local rep and see if he can help get a correct one for you.
The PAF is the license and security file and can be found usually under c:\delcam\paf\
Good luck!
Installing from the Live CD TonyZLR LinuxCNC (formerly EMC2) 8 01-30-2009 10:02 PM
Newbie- Problem with installing lazycam motogypsy Mach Software (ArtSoft software) 3 01-03-2009 11:07 AM
Problem installing Bobcad 2007 on Vista CNCadmin BobCad-Cam 5 01-01-2008 08:01 PM
Problem installing Mach2/3 Post youngfg BobCad-Cam 2 04-25-2007 09:53 AM
Installing Mach2 wholepair Mach Software (ArtSoft software) 3 12-15-2005 02:29 PM
