| FeatureCAM CAD/CAM Discuss FeatureCAM CAD/CAM software here. |
I am working on a part at work, and ran into a problem. I looked into feature cam's help and of course its no help at all. So here i am at home trying to figure it out on a simple surface i drew here to get the basic idea of the corner blend feature figures out. Now i know there is a way to fillet the edges and cornew blend of a 3D surface but im having no luck. I have attached an example part of what im trying to fillet the edges on and do the corner blend. If anyone can help you would kick a$$ Thanks P/K |
| first of all why in the world are you still working in surfaces?? you have solid wizard icon and its much simpler but if you prefer solids to each his own... in your surface wizard go to surface to surface fillet fill in your desired radius and there you have it Rick |
| I have no idea how to use the solids feature except to make the stock a solid. If i could get a little of explanation on how it works i could probally be up and running using the solids. I have looked all over in the tutors and no help. So were stuck using surfaces till the military will send us to the training class. I did try what you said and i still get an error. Im not sure if im drawing it wrong or what Thanks Dan |
| ?If using surfaces i recommend that you do a surface to surface trim first so as to excact the intersection but....if you do the stock solid as you mentioned then you can simply go to solid wizard and modify surfaces with a fillet are you with our armed forces sir? If you are and would like to provide me with an email address i will send you some very good self led training materials on 2.5 d and 3d and solid modeling Rick |
| Could you send me a copy? Thanks virgilingle@yahoo.com |
| Newbie- How to machine a fillet? | hxczach | Mastercam | 9 | 04-02-2008 07:02 PM |
| Can't Blend / Fillet this? Why not? | kprice1658 | Rhino 3D | 4 | 08-24-2007 10:33 PM |
| No fillet happening | R C | BobCad-Cam | 0 | 07-17-2006 03:43 AM |
| Problem with variable radius fillet | gibsonc | Solidworks | 4 | 05-15-2006 11:13 AM |
