Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > FeatureCAM CAD/CAM
FeatureCAM CAD/CAM Discuss FeatureCAM CAD/CAM software here.
Old 07-29-2008, 05:28 AM
dcalp is on a distinguished road
Simple question
do you part line program and if so why?
Old 10-03-2008, 09:06 AM
rick_7037 is on a distinguished road
I PartLine
So that I can use my machines Dcomp and insert whatever cutter i would like to
Old 03-24-2009, 08:58 AM
speeeeed is on a distinguished road
Centerline Because the tool path generated is more efficiently. You get alarms as they should be when running the machine. The less the guy on the floor has to input the less likley there will be an error.
Old 09-21-2009, 07:26 AM
Rover_928's Avatar
Rover_928 is on a distinguished road
6 to one half a dozen to the other.
We centerline and insert 0 for the tool dia value in the controller. Keeps it very simple and very easy to comp for.
Partline is fine we just don't use it. The code can be more difficult to read and make small edits at the controller if needed. Especially if using re-ground endmills.
Hi Just a simple question (Not a Machinist here sorry) R0gu3 General Metalwork Discussion 0 01-27-2008 09:46 PM
simple question moldmker General Electronics Discussion 2 10-26-2007 08:57 AM
Simple question monte55 Xylotex 2 12-02-2006 08:38 PM
Simple Question Simple Answer ? p3t3rv Stepper Motors and Drives 6 02-16-2006 09:00 AM
Simple question? johnney0005 General CNC (Mill and Lathe) Control Software (NC) 0 03-26-2005 10:52 AM
