Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > FeatureCAM CAD/CAM
FeatureCAM CAD/CAM Discuss FeatureCAM CAD/CAM software here.
Old 06-19-2008, 10:05 AM
almo0797 is on a distinguished road
FEATURECAM WITH SOLIDWORKS
Can the users of FC with SW models help me with some information.
1. Are the SW models programmed directly or do you import them in to FC? If importing is it the SW model or do you have to create another file ie STL.
2. Are the FC programs associative with changes to the SW models? If so to what extent is it fully or is it restricted to some type of features.
3. Is it easy to machine different parts together and does the simulation show all the parts machined?
4. Can the FC program be saved with or associated with the SW model so that copied SW parts that have been modified need very little input to produce a new program?
I know its a lot to ask but I would welcome your thoughts and experiences
Old 06-30-2008, 07:42 AM
tektonics's Avatar
tektonics is on a distinguished road
FC will open native SW files, you must choose this in the file type drop down menu. It also allows you to choose the configuration of the part if there are mutliple to choose from
To a limited degree, I have not found this function usefull as it often requires re-programming the part in FC
I think this goes back to question #2?
Old 06-30-2008, 07:51 AM
Is there a lot flexibility in the way AFR looks at the part? I've used Camworks and that could be made to suit some of our features be needed a fair amount of setting up. As a former Pro-E user I am looking for a CAM system that will readily update on models which have been copied and modified
Old 06-30-2008, 12:29 PM
tektonics's Avatar
Honestly there are people who are much better able to speak to this question, in my limited (couple of years) experience using FC, I find the AFR counter productive. I use the feature recognition function whenever possible, but often I still have to go and define curves and such. I think building your models with all this in mind is helpful. Most of the parts I design are not quite what FC had in mind when AFR was developed?
As far the parametric abilities of cam software... don't know.
FeatureCam Skillet FeatureCAM CAD/CAM 72 Yesterday 10:22 AM
Looking to buy used FeatureCAM inthezone FeatureCAM CAD/CAM 0 07-20-2007 03:48 PM
FeatureCam Help inglethomas FeatureCAM CAD/CAM 2 05-17-2007 08:33 AM
Looking to do autocad solidworks, or featurecam work VIRGIL INGLE Employment Opportunity 0 11-14-2005 05:52 AM
FeatureCam V11 Skillet FeatureCAM CAD/CAM 17 07-16-2004 07:41 AM
