Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > FeatureCAM CAD/CAM
FeatureCAM CAD/CAM Discuss FeatureCAM CAD/CAM software here.
Old 06-12-2008, 10:30 AM
Castle1 is on a distinguished road
surface mill from bottom to top
Does anyone know how to change the direction of surface milling? I dont mean climb or conventional, I'm refering to the overall starting point of the surface 3D. I've got the ball endmill milling just fine from the top of part down, I was wanting to mill from the bottom upwards (to use more of the side of the cutter).
I've tried changing z start & end but that does'nt work, also deselected mill top surfaces first.
Old 07-22-2008, 06:02 PM
doumralliart is on a distinguished road
its in the sfm properties , milling and selectect bottom up . sorry for my english ,i live in Quebec
Old 11-11-2008, 07:44 AM
rick_7037 is on a distinguished road
or a neat little trick if your parrallell machining change the parallel angle to 180 degrees
IE changing angle on an X parallel to 90 creates a Y parallel algorithom!
Total control thats what im talking about !
sorry..... im calm now.... tooooo much coffee.......
How to generate g-code to mill flat surface pminmo G-Code Programing 14 09-10-2006 12:33 PM
Milling top and bottom? bigvinney General Metalwork Discussion 7 01-28-2006 09:16 AM
Cutting the bottom surface lilricky2 BobCad-Cam 6 12-10-2005 11:41 PM
Look at my bottom Graham S DIY-CNC Router Table Machines 21 12-14-2004 02:12 PM
Ok so what is the bottom line? WallCrawler CNCzone Club House 8 06-19-2003 09:51 AM
