| FeatureCAM CAD/CAM Discuss FeatureCAM CAD/CAM software here. |
| Sounds like something that would be easy to change in the post processor setup. This is code meant to be run on a 'real' cnc or is it on a retrofit?
| It’s possible that the post processor is at fault but if it worked for you before I would look in the machining attributes or even a setting attached to the tool. This has happened to me before but so long ago that I forget what it was. Normally you will just have to select or deselect a box and all will be good again. Gary |
| Maybe a 'mirror toolpath' function of some sort would have that effect?
| I cant seem to find the setting to change...first time playing with the software in the lab at school. It works really good with solidworks 2007. The lab has a CNC but I want to save the NC to use on my DIY router. The CNC mill in the lab shows the G2 G3 reversed when graphed so some setting is wrong somewhere. |
| when i was setting up the post for my prototrak machines, i found that all of my g2 and g3 were swapped. I went into the post and into CNC-Info | NC Codes... I then swapped g2 to g3 and g3 to g2. It seemed to take care of all my backwards arcs. |
| Having weird problem | rustamd | LazyCam | 10 | 11-23-2007 06:58 PM |
| Eagle CAM Processor output - Mach3 Size issue | deleteallusers | G-Code Programing | 7 | 05-02-2007 10:14 AM |
| Weird stepper issue... | WilliamD | Stepper Motors and Drives | 0 | 07-21-2006 12:11 PM |
| Help with selector switch wiring issue (***actually a motor issue***) | BEDFORD | Industrial Hobbies (Support forum) | 7 | 04-07-2006 04:19 PM |
| Weird? | Klox | General CAM Discussion | 5 | 11-18-2003 11:04 PM |
