Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > FeatureCAM CAD/CAM
FeatureCAM CAD/CAM Discuss FeatureCAM CAD/CAM software here.
Old 12-03-2007, 10:08 PM
cornwallav8r is on a distinguished road
FeatureCAM - outside radius?
I am getting up to speed with FeatureCAM and have my part's outline drawn. I made all the appropriate curves, and extruded surfaces from them. So far so good, I made all the inside features, the faces, grooves, drilled holes and pockets. But now I want to use a ball mill to add a 1/4" outside radius around an extruded curve. How the heck does one go about this? Do I need a solid? Hopefully not, thus far everything I have wanted to do is easily done with curves and surfaces. Any help is most appreciated!
Old 12-04-2007, 11:27 PM
duluthboat's Avatar
duluthboat is on a distinguished road
You do not need a surface. If you have the curve you can make a feature from it. If you use the boss feature you can choose the depth and the the radius at the bottom of the feature. Then you can select the tools for rough, finish and radius.
Gary
Old 01-14-2008, 11:44 AM
rick_7037 is on a distinguished road
or if you already have the surface
"I made all the appropriate curves, and extruded surfaces from them. So far so good"
then just select the radius and a surface mill operation I have the best luck with x or y parallel happy coding!
FeatureCam Skillet FeatureCAM CAD/CAM 56 06-30-2011 01:30 PM
Looking to buy used FeatureCAM inthezone FeatureCAM CAD/CAM 0 07-20-2007 04:48 PM
FeatureCam Help inglethomas FeatureCAM CAD/CAM 2 05-17-2007 09:33 AM
Featurecam 2006 cnc wizard FeatureCAM CAD/CAM 5 10-24-2005 02:04 PM
FeatureCam V11 Skillet FeatureCAM CAD/CAM 17 07-16-2004 08:41 AM
