Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > FeatureCAM CAD/CAM
FeatureCAM CAD/CAM Discuss FeatureCAM CAD/CAM software here.
Old 08-25-2007, 06:50 AM
camtd is on a distinguished road
snapping to imported geometry
I have just downloaded featurecam 2008. I am playing with a parasolid file.
I am looking to machine a part using a hole to locate the Wcs. I have the snap set to the pick center but it will not pick at center.
How do you pick the center of a curve on a imported part?
Old 09-13-2007, 11:39 PM
Big Daddy is on a distinguished road
I don't know if you solved this but you probably did by now. Are you still interested? There are several different ways....
Old 09-17-2007, 05:34 AM
Not solved yet
Hi
No I just gave up. What would be one or two easy ways?
Thank You
Old 09-21-2007, 04:44 AM
SeymourDumore is on a distinguished road
My way is after importing the geometry as a new FC file, just exit out of the Setup Wizard, and then do a Surface Projection -> All surfaces -> Keep geometry.
Then restart the setup wizard and now you're able to snap to the center points.
Old 09-21-2007, 12:40 PM
I'm sorry I forgot all about you! I did a complete system rebuild from the F/disk & I haven’t reloaded my Feature Cam yet. But Seymour is right. I use that method religiously, it works great!
Old 10-13-2007, 06:53 PM
featurecamer is on a distinguished road
surface projection ?
Hi Folks,
I'm new to the solids in FC. I have also had trouble snapping to some types of imported solids. Could you explain the surface projection method further please?
Thanks,
Dan
Old 10-13-2007, 07:42 PM
Sure you click on the curves icon on the left of the screen, then create curves using the curves wizard, then on the top of the pop up window there are 3 choices, you click the 2nd on down (curve from surface), then click on surface projections. The wizard will then walk you through a conditioning process. I just click next then when you get the popup asking you to keep geometry say yes. Then the wizard burns all surface lines into the z surface of the stock in a 2-d generation. Plus the 3-d part still there as well.
Old 01-16-2008, 11:27 AM
rick_7037 is on a distinguished road
My favorite for this would be to let FC recognize the hole features ...If you have recognition
New Feature/Hole from dim/recognize box checked/
then align UCS and setup to the feature
I have found this quick and easy
Rick
Old 01-17-2008, 04:43 PM
also if you have a curve to pick center it needs to be geometry simply click from the pulldown construct-curve-to grometry then snap object of center will be visible be sure you have your curve preselected!
DFX is not imported correctly... ihkim GRZ Software- MeshCAM 11 01-07-2010 12:57 PM
How to move an imported file to X0,Y0? Shepard Mastercam 2 05-21-2007 02:51 PM
Heat treated 17-4 PH snapping taps eject_21 General Metalwork Discussion 4 04-14-2007 10:41 PM
Zeroing imported parts an0n Mastercam 4 01-10-2007 02:13 PM
imported rotary tables vacpress General Metal Working Machines 8 04-06-2004 11:03 PM
