Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > FeatureCAM CAD/CAM
FeatureCAM CAD/CAM Discuss FeatureCAM CAD/CAM software here.
Old 08-08-2007, 01:32 PM
Scott_M's Avatar
Scott_M is on a distinguished road
No A axis moves ? ( in post )
Hi Guys
I am having some trouble with 4th axis rotary indexing .
I have created a part that requires machining on 3 sides , I have created 3 different setups with the UCS 90deg apart. all seems to go well through the simulation. but when trying to output code I do not get any "A" axis moves. I have tried naming my setups the same and different. no change.
What I did to get the job done was uncheck "4th axis indexing" and outputted 3 different chunks of code and "stitched" them together with the appropriate A moves.
I have tried several post processors as well...No A axis moves.
I am sure that I am missing something...
Any help would greatly appreciated !!
Scott
Old 08-09-2007, 08:35 AM
Skillet is on a distinguished road
Are you using the 4 axis post?
Old 08-09-2007, 09:00 AM
tr13548 is on a distinguished road
Scott,
In your stock properties there is a checkbox to generate your g-codes for all setups in one file. Let me know if this fixes your problem.
Tony
Name:	4th Axix checkbox.jpg‎
Old 08-09-2007, 09:37 AM
Scott_M's Avatar
Hi Guys
Thanks for your replies !
I left a reply last night...I don't know where it went ????
It went something like this.....
Nevermind....I'm an Idiot
I was not using a 4-axis post.
Anyway..
I found a FADAL post that seemd pretty close
I edited Program start , End and Tool change. Now it looks pretty good.
I am running Mach 3 on a Tormach , I will test the post shortly and report back.
Thanks again
Scott
Converting G2 & G3 Moves to Rotary Axis? skibbey G-Code Programing 2 04-03-2007 08:40 AM
Changing Z moves Davidimurray Post Processors for MC 5 02-10-2007 02:59 PM
Routing image moves lockeyone WoodWorking 8 11-22-2006 02:18 PM
Rapid moves G00 dicksonhof Mach Software (ArtSoft software) 9 11-07-2006 10:21 AM
Z position moves up during run henryj1951 Gecko Drives 3 03-27-2006 06:16 PM
