Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > FeatureCAM CAD/CAM
FeatureCAM CAD/CAM Discuss FeatureCAM CAD/CAM software here.
Old 08-02-2007, 09:11 AM
SpringKing is on a distinguished road
Multiple Rough Issues
Does anyone use the Multipule tool in the rough mode? We have tried using it but it seems to cut alot of spots were it doesn't need to ( cuts air). We Are using a 3/4 " insert mill and 3D roughing a part out we then step down to a 1/2 " ball end mill, and it should just go in and get the corners that the 3/4 "
Mill missed but it does alot of stuff it shouldn't.
Old 08-09-2007, 08:38 AM
Skillet is on a distinguished road
Turn it off
You should go to the machine attributes and turn it off. 99% of the time you can use 1 tool to rough with, anyway.
Skillet
Old 02-09-2008, 12:01 PM
laamar is on a distinguished road
we had an issue with multi rough. A part we was machining was planned to be rough machined with a 18mm cutter the because the part had a few slots in 12mm wide we would step down to a 10mm cutter to rough out the slots, but when posted the 18mm was sent into the slots then the 10mm followed. Got intouch with egs they said the new version would fix this problem. but this was 6 years ago we run V7 then and still do. Had no opportunity to check new version.
Double Rough Cut problems inthezone FeatureCAM CAD/CAM 4 08-02-2007 01:12 PM
Rough Movement jhwatts Xylotex 2 09-28-2006 04:07 PM
Rough Cut of a thread Slythar Test Forum 0 04-09-2006 09:00 PM
truemill and z-rough and srm championp Surfcam 1 02-22-2006 10:51 PM
Stepper rough 1 direction randyf1965 PicStep Controllers 6 05-25-2005 03:17 PM
