Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > FeatureCAM CAD/CAM
FeatureCAM CAD/CAM Discuss FeatureCAM CAD/CAM software here.
Old 08-01-2007, 05:00 PM
inthezone is on a distinguished road
Double Rough Cut problems
I want to ream a 1/2" hole for a force fit bearing in 1/4" aluminum stock.
Given the tools I have, I have to do a pocket using my 1/4" roughing endmill, and then ream.
The pocket I created is .450 in diameter, at a depth of .27 (in FCAM). For some reason FCAM is calling up for a secondary rough cut with this pocket + the finish cut. I just want a regular rough and then finish.. no double rough cut.
I am unable to change the machining attributes, or milling strategy to remove this secondary rough cut... Whats the deal with this?
I get an error in my operations list telling me that this secondary rough cut is unecessary.. why does it keep coming up?
This seems a bit ridiculous..
Old 08-01-2007, 06:53 PM
HuFlungDung's Avatar
Moderator
WAG: have you checked for double entities?
Old 08-02-2007, 01:57 AM
duluthboat's Avatar
duluthboat is on a distinguished road
machining attributes, try "total stock"
Old 08-02-2007, 09:03 AM
SpringKing is on a distinguished road
You might check in milling attributes that multipule tool is not on
Old 08-02-2007, 01:12 PM
Yeah, Double Rough cut was set. Thanks guys!
Rough Movement jhwatts Xylotex 2 09-28-2006 04:07 PM
Rough Cut of a thread Slythar Test Forum 0 04-09-2006 09:00 PM
truemill and z-rough and srm championp Surfcam 1 02-22-2006 10:51 PM
' 04 VF 4 Rough Tool changing ap-machine Haas Mills 16 09-26-2005 08:56 AM
Rough drive == overheating 10bulls PicStep Controllers 5 07-12-2005 11:35 AM
