Results 1 to 4 of 4
Thread: Fanuc G75 Grooving Cycle post processor
    Jun 2006
    Scotland
    Hi Im looking for a post for a fanuc 21i which has the the g75 groove cycle or just the code that i can add to my own post if this is posable with featurecam
    thanks
    RK
    Registered duluthboat's Avatar
    Sep 2003
    The 21i post I have doesn’t use a canned cycle for grooving it computes the groove using its own feature. Canned cycles are great for MDI but if you use CAM software they can be tricky.
    Gary
    Jun 2006
    Scotland
    Thanks for the reply Gary
    We use g75 alot when we rough grooves as we do all our programing on the machines at the moment.I was looking to keep the code the same but the computed cycle worked fine on the test part (no reason why it shoudn't)
    A cam system is going to be a big change for us and is getting met with a little resentment at the moment as we test different systems
    RK
    Sep 2003
    RK,
    I understand completely, I look forward to the day when the Cam software is integrated directly in the controller.
    Gary
