Results 1 to 3 of 3
Thread: Need Post for Haas 3-axis Mill
    Apr 2005
    Does anyone have a good working post for a Haas 3-axis VMC? For me, the Haas posts are not working properly. Thanks
    Feb 2004
    The Haas post in your M-Library should work, no problem. Which machine do you have?
    Skillet
    Apr 2005
    ..I think I discovered my problem, and that is, for some reason, I adjusted the Fixture ID in my setups for whatever reason and in my post the Work offset was usually g54, and it was the 1 which I defined was my fixture ID. No go with the code. Had I known this earlier, I wouldn't have spent the better part of my afternoon debugging and reprogramming, and re-reprogramming, and editing my post, and then noticing the link between fixture ID and the work offset. arghh!
