you need both 4-axis, and 3D support to make that part. you have your stock set up and indexed properly. check your evaluation options and make sure you have 3D. if you have 3D, and feature recognition, you should be able to get toolpath with just a few clicks. sorry, I only have "3D-lite", so i cant help you beyond that. that is a complex part. very complex depending on how true to the solid you need to be.
LinkBack URL
About LinkBacks
