Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > FeatureCAM CAD/CAM
FeatureCAM CAD/CAM Discuss FeatureCAM CAD/CAM software here.
Old 11-11-2005, 05:42 PM
chestervomkorte is on a distinguished road
Postprocessor should get single program at every tool call
Hello !
Is there a way to get output from the postprocessor for every Tool call in a file?
At the moment we get one Program with many tool calls, only if I switch the setup's I can handle it, but what, if I have for e.g. a pocket with many tools?
We use a MAZAK Mill Machine, where we program the tools in mazatrol and then jump in an ISO-Program from Featurecam.
So I need for every tool call one ISO-Program from Featurecam.
Sorry for my bad English.
Old 12-18-2005, 09:15 PM
dmealer's Avatar
dmealer is on a distinguished road
Are you using the ISO programs as subprograms, calling them with a M98P* command. This works well with our mazaks.
Old 12-19-2005, 03:02 PM
Yes ,we write a MAZATROL-Program with the AGP.
Then we have a Tool-Call in Mazatrol and a subprogram call to the ISO-File generated from Featurecam.
At the End of the ISO-Program is a M99 to go back to the Mazatrol-Program.
Then you have maybe another Tool-Call and another subprogram to ISO.
So we mix the Mazatrol and ISO-Programs.
The Tool-Call in the ISO-Programs are nothing for us, because then you have Tool-Call 1, Tool-Call 2,... because you can't work with the Mazatrol Tools.
And you can't say you want again call the Tool-Call 2 in the ISO-Program.
Hope, anybody understand me.
Old 12-23-2005, 01:09 PM
drbest is on a distinguished road
Unterprogramme
hallo ,
wenn ich dich richtig verstanden habe, schreibst du das hautprogramm in mazatrol (werkzeugwechsel und drehzahlen), dann rufst du einfach das unterprogramm in ISO auf wo die bearbeitung programmiert ist.
vielleicht ist dass eine möglichkeit:
1. erstelle wie immer ein (*.fm) teil
2. erstelle eine neue Multiple Fixture (einfach 2 setup´s erstellen), zb. selber teil auf 2 schraubstöcken.
3. generiere das nc programm, jetzt hast du bei den bearbeitungen lauter unterprogramme. wichtig: dass du bei "post options" den haken bei "disable macros" raus ist.
dass hauptprogramm kannst weg werfen, oder wenn du dich gut im postprozessor aus kennst, dann kannst ihn so veränden, dass auch kein Hauptrogramm mehr erstellt wird.
tip: wenn du lauter einzelne files von den Unterprogrammen brauchst, dann editiere den postprozessor unter "general" bei den einstellungen "macro type" die einstellung auf "indiv. files" setzen.
ich hoffe dass hilft dir weiter.
gruss drbest
Old 12-24-2005, 07:46 AM
Hallo !
Dein Beispiel klappt !
Ist zwar etwas umständlich, aber Featurecam gibt mir jetzt wenigstens einzelne Programme aus.
Leider lauten meine Programme nun jedoch (z.B. wenn ich als Programmname 987 verwende) 987M01, 987M02, 987M03 usw.
Die Mazak kann aber nur Ziffern als Programmname.
Wo könnte ich das einstellen ?
Möchte also Programmnamen mit 98701, 98702, 98703 usw.
Gruss
chestervomkorte
Old 12-25-2005, 01:47 PM
Unterprogramme
hallo,
leider ist mir auch nicht bekannt wo und wie das "M" eingestellt wird. ich glaube du wirst nicht herum kommen die files von hand zu ändern oder du suchst dir einen file-renamer, die gibt es zu haufen als freeware im i-net. ich bin mir sicher, dass ganze könnte mit einem API automatisiert werden, aber leider kenne ich mich im SAXbasic nicht wirklich aus. sollte ich einmal auf eine lösung kommen, dann werde ich sie dir gerne weiter geben.
gruss drbest
