| FeatureCAM CAD/CAM Discuss FeatureCAM CAD/CAM software here. |
| Featurecam with Heidenhain TNC151 Anyone else running FeatureCAM to a Heidenhain TNC151 (Bridgeport Interact?) Spent best part of today scratching my head why the 'conversational code' generated by the INMTCM.CNC post processor kept giving error messages. Eventually found that it was generating 'orphaned feed rates' (ie just an Fxxx on it's own on a line) when starting segments, and also outputting angles to four decimal places and the control will only accept three. Reason for question - there are probably other issues I've not found yet ! AWEM
__________________ Andrew Mawson East Sussex, UK |
| Hello, I have not used Featurecam in a while, but I used to be decent with it's post processors. I know your 4 place decimal problem can be solved in the post. After opening FC, go to manufacturing at the top of the screen, then pick post process. With your post selected, chose edit. After the edit window opens, choose CNC info, then words1. The word section is where you can control the number of decimal places to the left and right of the decimal. There are several pages of words, so it may take some looking to find all that are related to angles. The format you will see will be something like this: On the words1 page the x cooridinat is probably set to 3.4. This means 3 places to the left and 4 places to the right. If you change it to 3.3 whola!! 3 places to the left and 3 places to the right. As for the orphaned feed rate, is it all the feed rates, or particular to a certain type of move? I hope I have helped. It has been a long time . Regards, Dalen Mealer |
Thanks for the response - much appreciated. I've actually solved the problems I know about - I'm looking for the problems I don't know about ! (Does this sound like Rumpsfeld !!!) The feed rate was part of the 'start segment' code which I have modffied. AWEM
| Are you running automatic tool changes or manual tool change post? I also modified to the 3.3 in mine, but I had to make several changes when it came to auto tool changes. It worked fine but was making extra moves for a tool change that I had to speed up. I also changes rapid moves in the post to FMAX and several other places in the post. Sometimes it would move at feed and not max and delay a tool change. |
| Well I'm still flogging away at the old copy of Featurecam but the Bridgeport Interact and TNC151b are now history - gone to the ultimate resting place at the scrap yard I moved and the carrier dropped the whole shebang off a flatbead onto the tarmac - not much worth salvaging.I'm now running a Beaver Partsmaster with a TNC355 and a 16 slot tool turret - sheer luxuary. Been adding bells and whisles - got a touch probe for tool setting - such modernity ! Blimey - 5 years since I started this thread - argh ! AWEM
