Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > FeatureCAM CAD/CAM
FeatureCAM CAD/CAM Discuss FeatureCAM CAD/CAM software here.
Old 10-19-2011, 11:22 AM
omnitech's Avatar
omnitech is on a distinguished road
Surface over a surface problem
If I have a surface with a pocket and some holes and I create another surface over it to hide them when doing surface milling, why does it still pick up the features under the surface even if I raise it up .001" Any ideas anybody?
Old 10-20-2011, 08:52 AM
dcalp is on a distinguished road
first, make sure they are not checked in the part surfaces
Old 10-20-2011, 09:03 AM
omnitech's Avatar
Thanks for the response dcscalp, I tried with it checked and not checked. it still wants to pick the pocket up under my created surface. I fixed it by slanting the part so that surface was parallel to the table that way I wouldn't have to surface mill it.
On the same part though, I'm milling the rest of it that's at an angle. I'm roughing with a 4 inch facemill. That's how big the part is. But instead of staying on the surfaced I've chosen, it wants to go around the side of the part where it would be cutting a lot of air. Any way around this?
Old 10-20-2011, 09:16 AM
this could get involved. what surface milling feature are you using? on the edges tab, do you have "don't roll over edges checked? on stock tab are you checking use "part surface dimension"? fill in some blanks---
Old 10-20-2011, 09:31 AM
omnitech's Avatar
I'm using z level roughing, So I dont get the roll over edge option. And I've tried to use part surface, stock and the boundary options.
Old 10-20-2011, 09:39 AM
rather than creating a new surface that way, i go to surface wizard- one surface- untrim surface and "fill in" holes and pocket- then set the z-end if necessary. it's hard without "seeing" the file- can you attach it?
Old 10-20-2011, 09:42 AM
omnitech's Avatar
Send me your E-mail through p.m and I'll Email it to you. Thanks.
Need Help!- Fillet surface to surface problem vincent13 Mastercam 6 02-10-2011 06:15 AM
Need Help!- Surface Problem ZeroDay Mastercam 3 10-22-2009 06:29 PM
Need Help!- Surface to Surface Filleting and Trimming cowpoke Mastercam 6 03-17-2009 08:42 AM
Surface finish problem gar Haas Mills 65 05-22-2008 09:01 AM
?! Please help me with this surface problem. Ben J Solidworks 2 09-29-2007 12:25 PM
