Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > FeatureCAM CAD/CAM
FeatureCAM CAD/CAM Discuss FeatureCAM CAD/CAM software here.
Old 06-30-2011, 09:29 AM
durgam605 is on a distinguished road
Multi fixture issues
I try to setup a part for multiple part machining, and Featurecam is not cooperating. I follow the steps, to use existing files, setup the fixture offsets, the multiple pieces, by adding files as the help menu says. But not all of the geometry comes in the new file. Just a couple features, and no solids. And I cant import any other data. This is my first time doing a multi setup, so not sure on this one.
Old 06-30-2011, 09:59 AM
I think its supposed to be this way now that i have messed with it more. It uses a main file that is existing for all modeling and programming, and loads it into the multi file program. This allows the user to only modify one model or program, and reload it into the multi setup. The solid model is purpopsely not brought into the file so that you cant change it. It forces you to change the main file.
Just an FYI
Old 06-30-2011, 02:53 PM
laamar is on a distinguished road
Mf files
I to find that you cannot edit mf files so you must make the main fm files are correct before importing them into multi fixture control
Old 07-01-2011, 07:54 AM
Ive noticed that. Its nice really. Im running three of the same part on my VF2.
And when I need to make a change, i only have to change one, and reload it. Pretty simple control method if you ask me! I havent used Mastercam, since X2, but i dont think that has anything like this.
Multi-part Fixture with Single Point Clamping Geof Work Fixtures and Hold-Down Solutions 35 08-21-2011 09:13 PM
Multi Cam MG 308 Pocock1 Commercial CNC Wood Routers 9 01-20-2011 01:14 PM
Fixture for PVC sheet turbo2ltr General Metal Working Machines 0 12-15-2009 07:19 PM
fixture offsets beartrax G-Code Programing 1 11-14-2008 06:19 PM
Vacumm Fixture SPEEDRE DIY-CNC Router Table Machines 1 11-23-2005 10:15 PM
