Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > FeatureCAM CAD/CAM
FeatureCAM CAD/CAM Discuss FeatureCAM CAD/CAM software here.
Old 05-08-2011, 02:30 PM
russellthackray is on a distinguished road
milling a chamfer
I have a right angle (already milled) 200 x 200 with a 7 mm rad in the corner on 27mm thick plate i need to put a 16mm chamfer around it problem is to get a tool big enough to do it i cant achive the 7mm rad is there a way i can do this with a small cham mill and blend the cuts ? simple job just got me stuck, any help would be great,thanks
Old 05-09-2011, 01:47 PM
dcalp is on a distinguished road
i don't know if this is what you want but, go to the FeatureCam web site, click on support, tech tips and look for "cutting large chamfers" it's a way to use a smaller tool to do a larger chamfer which is what i think you want- hope so!! Let me know----
Old 05-12-2011, 05:35 PM
thanks for that Ill have a look now.
Old 07-31-2011, 02:05 AM
mallory50 is on a distinguished road
chamfer
its a bit long winded but you could surface mill it with a ball nose
Chamfer chamfer mill or ball mill fjbart70 Mastercam 4 03-11-2011 11:27 AM
milling a chamfer with endmill Quick3 G-Code Programing 16 03-14-2008 11:24 PM
Chamfer milling speed data? JMFabrications General Metal Working Machines 6 09-13-2007 12:30 PM
Chamfer CharlesM479 Solidworks 3 04-11-2007 11:13 PM
Milling 37 degree chamfer around a circular piece... peter.blais General Metalwork Discussion 21 09-20-2006 12:47 PM
