| FeatureCAM CAD/CAM Discuss FeatureCAM CAD/CAM software here. |
I know the name of the software gives it away a bit!, but i belive you can do simple 3d milling ops on 2.5 d. All i want to do is quite a simple 45deg slope with a 5 mm rad at the top and bottom of it where it meets the flats , can anybody help ? |
| you can create a curve using the function. It'll give you several options for what type of curve you want to create, but if you are fairly good with trig you shouldn't have a problem. Once the curve is created, you can run it as a groove feature and cut your profile. I use this method quite often for the same type features. |
| Retrofit my Old Milling (Milling No. 0) | mistry_hemant | General CNC (Mill and Lathe) Control Software (NC) | 0 | 01-17-2011 04:08 AM |
| CNC Milling Machine Packages and Bespoke CNC Milling Machines | worldofcnc | Product Announcements & Manufacturer News | 0 | 05-27-2010 08:20 AM |
| Need Help!- PCB Milling | Holzwurm56 | Bridgeport and Hardinge Mills | 1 | 06-28-2009 01:59 PM |
| Offset Chain Milling vs Path Milling | ynnek | TurboCAD/CAM | 1 | 03-11-2009 05:29 PM |
| Milling with bottom vs milling with side? | REVCAM_Bob | CNCzone Club House | 13 | 06-30-2008 09:23 AM |
