| FeatureCAM CAD/CAM Discuss FeatureCAM CAD/CAM software here. |
After having built the toolpath and NC code is generated, I load the NC code into Mach 3. It all looks good except for the fact that the Z-axis movements generated by Feauturecam are backwards. The Z axis reads and interprets positive values as retracting the spindle, and negattive ones as plunging into the workpiece. For my setup (mill), this should be the opposite. Z-1.0 means retracting the spindle and Z 2.0 means moving the spindle down 2 inches. X and Y axis are good. Is their an option or setting in Feauturecam that will allow me to generate a reversed Z-axis? Any help is appreciated. |
So to take a cut it is a minus number and to raise the Z it is a positive number. So the machine is right, it's your thinking that's wrong. ![]() This is the trouble with being self taught, no one is teaching you the right way to do things. Phil |
| Thanks for your input M250cnc, although it didn't answer my initial question of 'does Featurecam have a Z settings option' , but thanks for the free lesson. I solved my problem by first admitting to myself that, yes I must be wrong about the positive and negative movements on the Z axis. I know I would of figured things out myself if I would of listened to my first instincts. Turns out Mach 3 has a settings option for the Z axis to be run in reverse. It took all but 5 seconds to implement the change and voila, perfect positioning with Featurecam. I think I've gone a long way having converted and old 1984 Journeyman 300 to be fully functional with modern electronics and Featurecam. Again thanks for the help. |
When the Z comes down it should read in the negative. If it does all is good. But that was not the problem you described. Phil Sent from my HTC Desire using Tapatalk |
I know you've now reversed the Z in Mach, but if you wanted to do it in Featurecam all you have to do is make minor changes to the post processor using the inbuilt editing facility
__________________ Andrew Mawson East Sussex, UK |
| Need Help!- Mori w/Yasnac LX3 has reversed x axis | hammerdown | Mori lathes | 1 | 07-20-2009 10:44 PM |
| z Axis reversed - Resolved | JamesJames | Mach Mill | 3 | 04-22-2008 08:03 PM |
| Y axis reversed | Legion99999 | Syil Products | 7 | 03-03-2007 11:43 PM |
| Don't hurt the noob ... 1 axis reversed, help | oddatwl | Xylotex | 2 | 02-14-2007 12:35 AM |
