Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > FeatureCAM CAD/CAM
FeatureCAM CAD/CAM Discuss FeatureCAM CAD/CAM software here.
Old 01-25-2011, 09:47 PM
CX750's Avatar
CX750 is on a distinguished road
Work Offsets in Multiple Fixture
When I use the MF option to setup two different parts it will not put the G54, G55, G56, etc in the txt file. The simulation in FC switches between each fixture and you can see the Fixture ID change in the Operations List in FC, however it never shows the G55 in the txt file. I end up going through and manually entering this and it will play just fine on the mill (Hurco Winmax). Is this something that will need to be changed in the post processor or am I doing something else wrong? Any help would be greatly appreciated.
Thanks,
Tim
Old 02-18-2011, 05:17 AM
Mark_PGC is on a distinguished road
Hi Tim - I had same problem. You need to mod your post to use multi fix (if not already). I found this works best with work offsets starting at G505, G506, G507 etc. Mark
Problem- Plotting files with multiple fixture offsets Neziah NCPlot G-Code editor / backplotter 2 04-25-2011 02:31 PM
help posting work fixture offsets instead of G92 rsm169 Mastercam 6 05-21-2009 06:49 PM
Multiple Work Offsets X3 timmydabull Mastercam 4 08-28-2008 12:54 PM
Need Help!- Multiple Work Offsets PinMan BobCad-Cam 3 06-06-2008 04:41 PM
Multiple Fixture Offsets Benji EdgeCam 5 05-02-2007 04:28 PM
