Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > FeatureCAM CAD/CAM
FeatureCAM CAD/CAM Discuss FeatureCAM CAD/CAM software here.
Old 08-18-2010, 05:57 PM
monstrum is on a distinguished road
Keep out / boundary for clamps
I think I have tried everything, but I must be missing something. I need to setup zones (for clamping) in my part that will not be milled away. I plan to mill everything inside first, then relocate the clamps to the inside and finish by cutting the outer border.
This works fine for parts which have a nice pocket inside them, but if the pocket is not fully closed, FeatureCAM wanders out and cuts the outside of the part as well (where the clamps are).
I want to set a simple curve or whatever that a certain feature will never cross, how can I do that?
Or maybe I'm just working against the program. So how can I do it differently? Here's a picture of the part:
Old 08-20-2010, 09:05 AM
dcalp is on a distinguished road
Real quick, look into boudary curves--- i'll look in later, gota go!!
Old 08-24-2010, 11:31 AM
MrWild is on a distinguished road
I believe you call the feature you wish to cut a m"side" when setting up your curves. Do not use the auto function for pulling out he feature. Use the string option to string together each face of the feature you want to machine. This way the cutter never goes to the outside. Be aware of the lead in and lead out for the cuts as the can hit other features of not set up properly
Stock to Leave when Milling from Boundary Curve SkyG MadCAM 9 11-23-2009 04:47 AM
Problem- boundary with slice plannar chaz6966 BobCad-Cam 1 02-24-2009 09:50 AM
Do you need boundary offset or pocketing... JohnKeklak Product Announcements & Manufacturer News 0 05-24-2007 10:12 AM
Boundary box from 9.1 to X? tt_raptor_90 Mastercam 3 06-08-2006 01:24 PM
BobART (v20) 3D Machine to Boundary mc9design BobCad-Cam 0 07-23-2005 06:16 PM
