| FeatureCAM CAD/CAM Discuss FeatureCAM CAD/CAM software here. |
I am playing around with Featurecam 2007 and having some fun. It seemed real easy to use up until this point. I have no problem creating 2.5D features but now I am trying to create a part that will be fixtured on a 5c indexer so it can be manually rotated and machined at 0, 90, 180 and 270 degree angles on my Haas Mini Mill. I can get the setups to show each set of cuts but not all together. I tried to turn on the 4th axis and that seemed to flip the part after each cut and cause a gouge. when I had the part rotating around the X axis like I want it. When I change the Stock axis to rotate around the Y axis it completes the simulation for the first setup but appears to flip the part and cut the profile from the bottom of the part. I have not worked on more than the first setup because I do not want to get too far and waste my time if it is not going to work as I want it to. Can anyone give me some pointer as to the right way to approach this? I am in over my head on this one. Thanks, Marc |
| Let's see if I get this right. Go to your stock page and click on indexing tab. Leave if on no multi-axis positioning and check generate a single program and all your setups will be run at one time with a stop between setups. Let me know---- |
| 5 Axis Haas questions | PBMW | Haas Mills | 12 | 04-14-2008 10:38 AM |
| Fadal 4th axis questions | carbidecraters | Fadal | 5 | 02-20-2008 10:13 PM |
| 4 axis questions | spoiledbrat | WoodWorking | 1 | 11-13-2007 12:08 AM |
| X and Y axis rod questions | Mick Jagger | Linear and Rotary Motion | 4 | 03-21-2007 09:29 PM |
| X and Y axis rod questions | Mick Jagger | Linear and Rotary Motion | 10 | 03-06-2007 02:00 PM |
