Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > FeatureCAM CAD/CAM
FeatureCAM CAD/CAM Discuss FeatureCAM CAD/CAM software here.
Old 05-06-2005, 12:17 AM
jfong is on a distinguished road
Left or right side cutter contour
I'm testing the demo version of Featurcam11 2.5D and having a small problem trying to figure out how to set the toolpath to follow the left or right side of a curve. There is the groove feature but that seems to only set the toolpath to follow down the center of a curve.
If you choose inside/outside groove instead of face, you get a list of slot cutting type tool bits and not end mills?????
I have used mastercam before and it was easy to choose left, center, right computer compensation to do this.
Is there an easy way to do this?
Jim
Old 05-06-2005, 11:02 AM
*Registered*
pmurray is on a distinguished road
jfong,
After selecting the new feature wizard, select from curve: 'side'.
As it walks you through the settings, you will come to a screen that will let you select the direction/side of the curve you want the tool to cut on.
Hope this helps,
plm
Old 05-06-2005, 12:27 PM
I think I figured it out now. When I tried using the "side" feature before to cut the inside of a circle, it would pocket the whole interior. That was not want I wanted. I deleted the roughing out step and just used the finish step. It now does what it is suppose to do.
Thanks.
Old 05-08-2005, 11:35 AM
duluthboat's Avatar
duluthboat is on a distinguished road
Another option for cutting inside or outside of a circle without cutting all of the extra material is to set “total stock” to maybe .005 in rough. Then you can use the finish for clean up. I often use a roughing end mill then change tools to get a good finish. Check out “total stock” in the help file, it is a useful tool.
Gary
Cutter comp problems scottsss G-Code Programing 49 11-30-2011 11:47 PM
long cutter options Losos DIY-CNC Router Table Machines 28 06-28-2007 02:19 AM
Machining 1020 Steel with Inserted Cutter Machine1 Hard and High Speed Machining 6 01-26-2004 09:26 AM
How does G 41, G42 works ? BanglaTech General CAM Discussion 7 11-04-2003 12:38 PM
contour profile stevieboy Mastercam 8 10-15-2003 02:40 PM
