Hello, trying to work out how to cut a gear/spline on a shaft. Machine is a Haas VF2 with a 4th. Gear is a simple straight gear and we purchased a Vargex Insert gear cutter and inserts for our geometry. As far as what I need its very simply arc in, straight line, arc out, index and repeat. I am using the Solidworks model and have used the curve tap to create a gear curve. What feature should I use to cut the curve grove/side/surface milling. Have tried most but doubt I'm doing it correctly. Still fairly new to FeatureCAM so any help is appreciated. Zach
