you can go into the "Tool manager" and rename any tool. or you could "Make a copy" of a tool, and just rename it that way, then remove the "Old" tool from your Tool crib.
Hi guys, i need help regarding this:
(DATA-3/4/2015 - REV.0)
( TOOL LIST )
( TOOL NAME )
( U-Drill D21 TwistDrill 21.00 80.00 1 )
( HSS.F D20. EndMill 20.00 100.0 2 )
( C.E D16.0 EndMill 16.00 100.0 3 )
( Ambore D6 SpotDrill 6.000 100.0 4 )
( Burghiu D2.6 TwistDrill 2.600 80.00 5 )
( TarodM3 Tap 3.000 50.00 6 )
i want istead of this (see up) to show me something like this:
(TOOL LIST)
(T1=U-DRILL D21)
ETC
basically without the aditional info for the tool.....
Many thanx
"If everyone is thinking alike somebody's not thinking!"
HAAS TM-3P and a HAAS OM-2
The thing is that the code is inserting something that i dont want like aditional tool name "TwistDrill, EndMill etc", diameter and so on, and it wont show the Tool Numer in front of tool name....
it won't show the tool number where? in the code after its output? you have to tell it what tool group its from, so it knows where to put it in the library. if you need to change the tool number, go into "Tool mapping" and change the tool number there
You want it to look similar to this?
O0001
(126487) (4-30-2015)
(126487 REV 2) (11:02.4)
( ROUND STOCK - INCONEL_718. OD 2 ID 0.9 Z 1.93 )
( ROUGH BORE TO .990 - 1.00 )
( LENGTH SHOULD BE 1.860 - 1.855 )
( T1 = 20S OFFICE ROUGH )
( T7 = FIN ISCAR CCMT BORING BAR )
( T7 = ISCAR CCMT BORING BAR )
( T9 = 15/16 ISCAR DR DRILL )
N100 ( ROUGH FACE2 )
G28 U0
G28 W0
G00 T0100 (20S OFFICE ROUGH R0.0313)
G0 X6.0 Z6.0
M40
G50 S1000
G99 G96 S100 M3
G0 X0.25 Z0.1 M8
G72 P95 Q105 U0. W0.02 D0.01 F0.004
Obviously I have (tool list) in my post, but I also have this Addin turned on "Add stock tool list and setup sheet.bas". I believe I downloaded that Addin a long time ago. Not sure if its still availible. If you dont understand Addins, heres a link FeatureCAM - Addins - www.featurecam.com
I can email you the Addin if you cant find it.
Thats exactly what i want from my tool list, you can send me via florinsid@yahoo.com, much apreciate
