Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > FAQ of CNC Machine building
FAQ of CNC Machine building Post CNC Router machine FAQ's and answers here! (Note all posts are moderated and once approved will be posted.)
Old 08-16-2004, 10:34 PM
ynneb's Avatar
Moderator
ynneb is on a distinguished road
What is a linear bearing ?
A linear bearing enables a mass to be moved along path with very low friction.
They come in all shapes and sizes.
Linear bearings are used with most CNC machines in order to give high precision movement control.
gas pipe & linear bearing dimensions relationship zoltan Linear and Rotary Motion 6 06-13-2005 04:12 PM
Linear Bearing mat’l? jakk100 Linear and Rotary Motion 19 05-18-2005 01:15 PM
a cheap linear bearing mocnc DIY-CNC Router Table Machines 8 03-26-2005 05:52 PM
Linear bearing spacing & Sizing linear rails? fyffe555 DIY-CNC Router Table Machines 3 12-07-2004 02:09 PM
build your own linear bearing CNC Brute DIY-CNC Router Table Machines 4 02-07-2004 04:32 AM
