You need a VFD to power and control that spindle.
110V Variable Frequency Drive Inverter VFD 1 5KW 2HP 13A | eBay
If you want to control the rpm from within Mach3, you'll need additional hardware.
Hey guys,
So I bought a 3040CNC Router on eBay a while back and have been having a blast with it, I'm up and running and making parts and what not. But..... as with everything.... I want more! haha. I've decided to upgrade the spindle motor (original one was weak at 200W/8000RPM). The eBay auction came with a controller and a turnable knob to control the rpms. The spindle I'm looking at is:
110V ER11 1.5kW Water Cooled Spindle (24k RPM, I realize it's water cooled and have that taken care of)
Listing of CNC Router I purchased a while back: 3040CNC Router with Controller
The question I have is, what all do I need to make this work with my current setup? Is it just plug and play or is there additional stuff I need to buy? I'm HORRIBLE with electronics and understanding if something is compatible or not. I've poured over the forum with the search function but again, I just don't understand electronics very well!
Please, please could someone help me?
UCCNC 2017 Screenset
I don't necessarily want to control from Mach 3 for now, controlling the spindle/rpms from the controller for me is good as it makes me double check myself before I cut each time. So no way around buying that VFD? I guess an upgrade means an upgrade in money too!
I guess I wish I would have just ponied up the extra cash for a bigger/better machine to begin with but that's the typical mistake for all hobbists I assume!
So - If i buy that spindle w/ the VFD, that means I have a controller for the CNC router to turn on, then I'll have to turn on the separate VFD (and input RPMs), turn on the cooling system and then start the cutting in Mach3? Sorry, I just need black and white as I'm not electronically skilled! Really, thanks again for the help!
pm sent
