Old 02-22-2010, 04:34 PM
samiahmed is on a distinguished road
Refernce return error
hello we have a Hitachi Seiki 4NE-600 lathe and it's giving me a code of "048 REF RTN" what they mean and How can I solve this problem?
where can I find a list of all the alarm codes and
thank you
Old 02-22-2010, 05:26 PM
dcoupar's Avatar
You don't specify what model Fanuc you have. The only explanation for alarm 048 is from the 6T- Model B Operator's Manual:
"G30 was specified without performing reference point return after the power was turned on or an emergency stop was executed.
A move command was executed without performing reference point return after the power was turned on or after an emergency stop was executed which incluedes optional stored stroke limit."
Sounds like you need to do a manual Reference Point Return (home).
Zero return bubba107 Emco Mills 0 10-21-2009 07:49 PM
Return to Zero mikemill Machines running Mach Software 0 08-25-2009 02:47 AM
Need Help!- Zero return problem, 11M force2eng Fanuc 14 03-09-2009 07:16 AM
Z return margin error Shotout Haas Mills 3 10-15-2006 10:05 AM
Fanuc 18M Z return pinguS Fanuc 12 07-26-2006 09:43 PM
