Hello all. I recently purchased a Leblond Makino FNC that has a Fanuc 11M control. I have multiple copies of the manual regarding the conversational section of the control, but nothing that covers the standard operations. ie. g-codes accepted, offset settings, program calling sequences, etc. Anyone have a copy of this manual and need a copy of the conversational manual?? Is Fanuc the place to go if I need to purchase the manual? Thanks for any help, |
| 0 rapid positioning G1 linear interpolation G2 circular/helical interpolation (clockwise) G3 circular/helical interpolation (c-clockwise) G4 dwell G10 coordinate system origin setting G17 xy plane selection G18 xz plane selection G19 yz plane selection G20 inch system selection G21 millimeter system selection G40 cancel cutter diameter compensation G41 start cutter diameter compensation left G42 start cutter diameter compensation right G43 tool length offset (plus) G49 cancel tool length offset G53 motion in machine coordinate system G54 use preset work coordinate system 1 G55 use preset work coordinate system 2 G56 use preset work coordinate system 3 G57 use preset work coordinate system 4 G58 use preset work coordinate system 5 G59 use preset work coordinate system 6 G59.1 use preset work coordinate system 7 G59.2 use preset work coordinate system 8 G59.3 use preset work coordinate system 9 G80 cancel motion mode (includes canned) G81 drilling canned cycle G82 drilling with dwell canned cycle G83 chip-breaking drilling canned cycle G84 right hand tapping canned cycle G85 boring, no dwell, feed out canned cycle G86 boring, spindle stop, rapid out canned G87 back boring canned cycle G88 boring, spindle stop, manual out canned G89 boring, dwell, feed out canned cycle G90 absolute distance mode G91 incremental distance mode G92 offset coordinate systems G92.2 cancel offset coordinate systems G93 inverse time feed mode G94 feed per minute mode G98 initial level return in canned cycles Examples: G1 X0.0 Y1.0 F20.0 ----go to X1.0, Y0.0 at a feed rate of 20 inches/minute G2 X1.0 Y0.0 I0.0 J-1.0 ----go in an arc from X0.0, Y1.0 to X1.0 Y0.0, with the center of the arc at X0.0, Y0.0 G1 X0.0 Y1.0 F20.0 ----go to X1.0, Y0.0 at a feed rate of 20 inches/minute G2 X1.0 Y0.0 R1.0 ----go in an arc from X0.0, Y1.0 to X1.0 Y0.0, with a radius of R=1.0 G53 motion in machine coordinate system G54 use preset work coordinate system 1 G55 use preset work coordinate system 2 G56 use preset work coordinate system 3 G57 use preset work coordinate system 4 G58 use preset work coordinate system 5 G59 use preset work coordinate system 6 G59.1 use preset work coordinate system 7 G59.2 use preset work coordinate system 8 G59.3 use preset work coordinate system 9 M0 program stop M1 optional program stop M2 program end M3 turn spindle clockwise M4 turn spindle counterclockwise M5 stop spindle turning M6 tool change M7 mist coolant on M8 flood coolant on M9 mist and flood coolant off M26 enable automatic b-axis clamping M27 disable automatic b-axis clamping M30 program end, pallet shuttle, and reset M48 enable speed and feed overrides M49 disable speed and feed overrides M60 pallet shuttle and program stop group 1 = {G0, G1, G2, G3, G80, G81, G82, G83, G84, G85, G86, G87, G88, G89} - motion group 2 = {G17, G18, G19} - plane selection group 3 = {G90, G91} - distance mode group 5 = {G93, G94} - spindle speed mode group 6 = {G20, G21} - units group 7 = {G40, G41, G42} - cutter diameter compensation group 8 = {G43, G49} - tool length offset group 10 = {G98, G99} - return mode in canned cycles group12 = {G54, G55, G56, G57, G58, G59, G59.1, G59.2, G59.3} coordinate system selection group 2 = {M26, M27} - axis clamping group 4 = {M0, M1, M2, M30, M60} - stopping group 6 = {M6} - tool change group 7 = {M3, M4, M5} - spindle turning group 8 = {M7, M8, M9} - coolant group 9 = {M48, M49} - feed and speed override bypass There are other codes; the type codes can be thought of like registers in a computer X absolute position Y absolute position Z absolute position A position (rotary around X) B position (rotary around Y) C position (rotary around Z) U Relative axis parallel to X V Relative axis parallel to Y W Relative axis parallel to Z M code (another "action" register or Machine code(*)) (otherwise referred to as a "Miscellaneous" function") F feed rate S spindle speed N line number R Arc radius or optional word passed to a subprogram/canned cycle P Dwell time or optional word passed to a subprogram/canned cycle T Tool selection I Arc data X axis J Arc data Y axis. K Arc data Z axis, or optional word passed to a subprogram/canned cycle D Cutter diameter/radius offset H Tool length offset Partial list of M-Codes M00=Program Stop (non-optional) M01=Optional Stop, machine will only stop if operator selects this option M02=End of Program M03=Spindle on (CW rotation) M04=Spindle on (CCW rotation) M05=Spindle Stop M06=Tool Change M07=Coolant on (flood) M08=Coolant on (mist) M09=Coolant off M10=Pallet clamp on M11=Pallet clamp off M30=End of program/rewind tape (may still be required for older CNC machines) G00 Rapid positioning G01 Linear interpolation G02 CW circular interpolation G03 CCW circular interpolation G04 Dwell G05.1 Q1. Ai Nano contour control G05 P10000 HPCC G07 Imaginary axis designation G09 Exact stop check G10/G11 Programmable Data input/Data write cancel G12 CW Circle Cutting G13 CCW Circle Cutting G17 X-Y plane selection G18 X-Z plane selection G19 Y-Z plane selection G20 Programming in inches G21 Programming in mm G28 Return to home position G30 2nd reference point return G31 Skip function (used for probes and tool length measurement systems) G33 Constant pitch threading G34 Variable pitch threading G40 Tool radius compensation off G41 Tool radius compensation left G42 Tool radius compensation right G43 Tool height offset compensation negative G44 Tool height offset compensation positive G45 Axis offset single increase G46 Axis offset single decrease G47 Axis offset double increase G48 Axis offset double decrease G49 Tool offset compensation cancel G50 Define the maximum spindle speed G53 Machine coordinate system G54 to G59 Work coordinate systems G54.1 P1 to P48 Extended work coordinate systems G73 High speed drilling canned cycle G74 Left hand tapping canned cycle G76 Fine boring canned cycle G80 Cancel canned cycle G81 Simple drilling cycle G82 Drilling cycle with dwell G83 Peck drilling cycle G84 Tapping cycle G84.2 Direct right hand tapping canned cycle G90 Absolute programming (type B and C systems) G91 Incremental programming (type B and C systems) G92 Programming of absolute zero point G94/G95 Inch per minute/Inch per revolution feed (type A system) Note: Some CNCs use the SI unit system G96 Constant surface speed G97 Constant Spindle speed G98/G99 Return to Initial Z plane/R plane in canned cycle I think If you have any more confusion mail me on prabhatmishra@mail.com |
| I NEED: DX-32 manual, 1104-2832 VMC Operator's Manual, DX-32 CNC Control | vettespeed | Bridgeport and Hardinge Mills | 27 | Today 08:21 PM |
| Manual and CNC Control? | Dave Berryhill | Industrial Hobbies (Support forum) | 8 | 10-20-2009 11:57 AM |
| manual cutter comp on lathe with fanuc control | madmachinist77 | General Metalwork Discussion | 0 | 01-08-2009 09:37 AM |
| Need Help!- FANUC O-MD Control MAnual | m_bhui | Mastercam | 4 | 11-03-2008 10:58 PM |
| Looking for hardinge vcm 1000 with fanuc 0-md control maintenance manual | samu | Bridgeport and Hardinge Mills | 5 | 09-02-2008 08:36 AM |
