Old 02-20-2010, 05:44 AM
ThomasS is on a distinguished road
Alarm 403: VRdy off , Fanuc OM
Hello,
I have big Problems with my "new" Hobby Machine:
I bought a OKK, with Fanuc OM + PMC, AC Servo, `90th Sporadically, I can not turn on the machine, it comes, the alarm 403, less often, the alarm 401 The machine has connected only 3 axes, according to the Manual, the alarm 403 for the 4th Axis??
But sometimes not, turning on, then the machine is working properly.
I already have all the cables, the connectors, fuses, checked the voltages and compared, are all ok The release voltage is forever.
For error description:
If this error occurs, go to the Servocards, the LED DRDY very briefly (one tenth of a second or so) lights and go off again, and the error message comes directly on the screen. Somehow it looks to me as if a contactor does not stop there?
Can i turn off the VRDy Alarm? Ignore or so?
Thanks from Germany,
Thomas
Old 02-21-2010, 01:58 AM
greenery_fr is on a distinguished road
Hello
Originally Posted by ThomasS View Post
Hello,
Thomas
PM me your email I will send for you two pdf file for 401 and 403
Old 04-26-2010, 05:57 AM
In the meantime I have replaced the capacitors, as it was not tuned well.
I'm still in search for the sporadic errors. Unfortunately I can not installed in the OM software switch the "Ignore VReady: off" it was only at later Versions.
Someone else an idea?
Greetings, Thomas
Old 10-18-2010, 11:28 PM
khongdamdau is on a distinguished road
I have a problem with my cnc milling machine (fanuc om control):
when starting the screen shows " alarm message: 1039...." and the machine is working nothing.
Anybody can help me? thanks in advance.
Old 10-20-2010, 02:04 PM
tmbruno28 is on a distinguished road
simple... there is same old version of software who says al 403 ,not for the fourth axis, but for the third (Z) axis ...So, if your servo amplifier is one 6058 series, exchange contactor ..
Old 11-17-2010, 03:17 PM
Hi Bruno,
the test will I suspect I already had. I have another exchange axis control.
I report.
Greetings, ThomasS
Old 11-18-2010, 06:09 PM
cncserveng is on a distinguished road
kongdamdau...... 10xx numbers are PMC errors and should be in the OEM operators manual, most likely a switch or something.
Old 01-06-2011, 02:35 PM
I believe I have solved the problem: When you switch on, there was too high Inner resistance at the fuses, there was micro welding at the caps. Since then I've fixed it, (i have polished the fuses) no error occurs more. I had previously changed all assemblies, unsuccessful!
Greetings, Thomas
401 servo alarm (VRDY off) sting Fanuc 36 07-01-2011 02:45 AM
Need Help!- 401 servo alarm (VRDY OFF), at turn on, Fanuc OM SOLVED padobranac Fanuc 16 04-25-2011 12:48 PM
Need Help!- VRDY OFF Alarm NID Fanuc 11 02-04-2010 09:47 PM
401 alarm (VRDY OFF) sting Fanuc 4 03-20-2007 08:47 AM
Not Ready and VRDY Errors brgrii Fanuc 2 10-05-2006 05:51 AM
