Old 02-13-2010, 08:04 AM
Molds0 is on a distinguished road
Fanuc 11 A comedy of errors
I am new here, not sure this is the correct category, but I have a problem...
My machine repair guy left my O9xxx macros unlocked on my Toyoda FH-55, my laptop (that had my backup programs) got a virus and had to have the OS re-loaded, and my night shift operator deleted ALL my files in the control memory.
My tool change program was O9000, and was registered, so I cannot call a tool without it, I can run an M6 tool change, but it just changes from tool zero to tool zero.
Does anyone have a quick solution? A copy of a tool change macro would be helpful, I could write one, but just don't know what parameter I need to be able to tell the control what tool it is supposed to go get.
I know this is a stupid problem, and I should have had another backup, as well as a hard copy, but I have jobs that need to ship (After I re-program them)
Any help would be greatly appreciated!!!!!!!!
Old 02-13-2010, 11:29 AM
Tool change macro
A bump so I can find this post
Old 02-13-2010, 02:32 PM
Al_The_Man's Avatar
Did you try Toyoda as a long shot?
They must have had them in there originally.
If you succeed in getting them, even a hard copy is nice, at least it is just a case of typing in.
Old 02-13-2010, 03:41 PM
dcoupar's Avatar
I agree with Al. The Toyoda dealer in Ohio is Yamazen.
Name:	Ohio Toyoda Dealer.jpg‎
Old 02-14-2010, 10:07 PM
sinha_nsit is on a distinguished road
Quick solution?
If working with only one tool, change it manually at a safe position, delete the tool change code from the program, and execute it!
Old 02-15-2010, 05:38 AM
The one tool is an option, just making sure the operators get the right tools in at the right time, for each part. I am afraid it is a mistake waiting to happen. The major roughing tool we use on the job, we already ran through the first 20 parts, I will attempt to contact Yamazen today, we have dealt with them in the past, although never regarding the Toyoda.
Thanks for your suggestions, I am at least in a better place and able to think it through a little more clearly without wanting to commit violent acts right now.
Old 02-15-2010, 08:31 AM
Lightbulb
Solved!
Okay, first thank you for your attempts to help!
Yamazen for whatever reason is closed today.
Here is what I discovered, in case someone in the future has a similar problem:
I figured that they had to store the tool number somewhere, so I just called a tool, then looked for that value. When I found it, I called another tool to see if it changed.
When the original programmer registered the program, they had it write the tool number to macro parameter #149.
Basically I wrote a program that looks like this:
O9000;
G80:
G91 G30 Z0;
X0Y0;
G90;
M9;
M5;
M19;
T#149;
M6;
M99;
It was just that simple!! I think I was just upset enough at all the stupidity (My own included) that I wasn't thinking straight.
Again, thanks for all that tried to help.
Old 02-15-2010, 09:52 AM
stevo1 is on a distinguished road
Good job. Got it on your own.
Stevo
Tags
fanuc 11m, macro, tool change
Need Help!- Mori Seiki Fanuc 6M ALARM ERRORS HouTX Fanuc 5 12-02-2010 05:55 AM
Need Help!- FANUC LADDER III ERRORS CHAD LAWSON Fanuc 0 08-14-2008 07:42 AM
SX3, Comedy of errors, fixes, suggrstions and information Old Megawatts Syil Products 15 12-11-2007 09:58 PM
Fanuc series 15 servo errors garysparks Fanuc 4 05-22-2007 09:18 PM
