Old 02-12-2010, 09:00 AM
laserray's Avatar
laserray is on a distinguished road
FANUC 16M Problems...
Getting the following:
-414 SERVO ALARM Y AXIS DETECT ERROR
-Diagnostic display reads "REGENERATIVE DISCHARGE CURRENT ALARM IS BEING GENERATED IN SERVO AMP-CHECK LED"
-Servo amp has 3 display options, 5=READY, - (dash)=not ready, 0=alarm. It displays the dash (not ready)
It has happened to me twice while machine is running, but most times its at start up, it seems that after it warms up a bit inside the panel it will display ready (5) and it will start up, I am unable to move either axis until it diplays ready. It took 2 hours to get it going this morning. Once fault clears runs fine but problem again in the morning. Thx in advance for your help
Old 02-14-2010, 10:04 PM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
Work your way through this and report back
GL.
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
Need Help!- Fanuc 11 crt problems bofr Fanuc 6 11-23-2011 01:41 AM
Need Help!- Fanuc DNC problems bigfoot Fanuc 0 01-25-2010 10:34 AM
FANUC 5T problems Dragoon2 Fanuc 9 12-12-2008 12:24 PM
Fanuc Problems timmyv CNC Machining Centers 0 09-23-2008 04:05 PM
Fanuc Problems scuba General Metalwork Discussion 6 03-19-2005 01:19 PM
