I've tried to get the rs232 interface to work, all settings are OK (or at least thats what I think). I'm using SDNC II (comes with surfcam), I can download the program in the machine but when I start the execution there is a buffer overflow alarm. Im using 4800 baud, 8 data bits, 1 stop bit, even parity bit, Xon/Xoff handshaking. I've read many cases where the problem was solved using handshaking but I've tried all and there is still a buffer overflow. If anyone could help me that would be great. |
| A couple of questions: Is your PC a laptop, and are you using a USB to serial converter? Are you trying to drip feed, or are you just sending a program to the CNC? I know that some buffer overflow problems are solved by disabling the FIFO buffers for that port. Go to Start - Control Panel - System - Hardware Tab - Device Manager - Ports. Double click on the COM port you are using. In the Port Settings tab, click Advanced. Move both sliders all the way to the left. Click "Do not use FIFO buffers" OK all dialogs. Reboot your PC. |
well, is not a laptop, is conected directly to the serial port of the computer. I had already tried setting the FIFO buffer to the lowest value but not disabling it. I can run small programs, big ones get the buffer overflow. Thanks so much. |
| Need Help with rs232 connection LB-15 | WGJ | Okuma | 9 | 03-10-2011 02:25 PM |
| Need Help!- fidia rs232 connection | digitallan | General Metal Working Machines | 0 | 09-27-2008 04:28 PM |
| USB to RS232 connection | stevo1 | Machine Problems, Solutions , Wireless DNC, serial port | 32 | 08-16-2008 01:15 AM |
| Need Help!- pc-2100 rs232 connection | blues_12 | Machine Problems, Solutions , Wireless DNC, serial port | 0 | 04-22-2008 12:47 PM |
| RS232 connection of Sodick A320D AWT EX21 | Mouldmaker | General CAM Discussion | 2 | 10-20-2003 06:36 AM |
