Old 02-11-2010, 08:33 AM
quasarix is on a distinguished road
Absolute cords reset in handle mode
Greetings!
I have a small problem on my Fanuc 18M (model c) Milling machine.
Problem is when i move any axes in handle/jog/rapid manual mode my Absolute value gets reset and set to machine axes in reference zero return position, so if you then start program it will travel totally wrong unless i zero return all axes and start.
Anyone got idea?
Old 02-11-2010, 09:59 AM
chucker's Avatar
chucker is on a distinguished road
manual absolute
Originally Posted by quasarix View Post
Greetings!
Anyone got idea?
I am not sure but I think you will find a switch on your control that says manual absolute and it needs turned on or off maybe someone else can jump in and shed some light on this?
Old 02-11-2010, 02:15 PM
I think i found the solution
its under parameter 8140
IFM
Specifies whether interference between tool posts is checked in the
manual operation mode.
0 : Not checked
1 : Checked
Also i have to check parameters 8162,8163, 8180....3, 8186 and 8200 (master/slave tool path stuff)
will try it tomorrow, wish me luck
Old 02-11-2010, 02:52 PM
underthetire is on a distinguished road
Absolute or incremental in manual mode parameter...or...some machines have a manual incremental button on the panel-Shizouka was on that did.
Old 02-12-2010, 08:53 AM
IFM
0 : Not checked
1 : Checked
damn all those parameters are empty
Old 02-12-2010, 05:14 PM
Ozemale6t9 is on a distinguished road
Are you using either G92 or G53 in your program? Can you post a photo of your operator's panel?
Old 02-13-2010, 10:59 AM
i dont use G92, I use G54,..
cant post panel right now will do it later.. but it doesnt have any knobs/buttons for setting anything like what i need
absolute cors value is calculated from zero return to G54, G55 etc whatever is currently running it works ok if i start from zero return position, and later it works with program normal, but when i manualy move table with handle/jog/rapid it doesnt recaculate absolute to G54 but it sets it like table is at zero returned position, and then when you run program for example G0 G54 G90 X0 Y0 it will go to wrong absolute cords (table at middle for example but absolute cords calced like its at zero return after i manual moved a bit) so it that code then travels table like its moving from zero returned positions if you get what i mean lol, its probably some parameter orr something i dont know...
Old 02-14-2010, 04:46 AM
It really does sound like what underthetire said. That's why a picture might help us identify it for you.
regards, Oz
Old 02-14-2010, 01:56 PM
regards, Oz
will make youtube movie so you can see
Old 03-04-2010, 03:18 PM
I still didt solve the bugger
here is video if that helps
  #11   Ban this user!
Old 03-04-2010, 04:12 PM
This is behaving exactly like manual absolute is on. What are the buttons that are switched on (lit) in your video? Can you post a picture of the control panel so we can see all the buttons.
  #12   Ban this user!
Old 03-07-2010, 02:03 AM
there are no buttons for that whatsoever on this machine or i would know...
its somewhere in parameters or keepreley that isnt specified in manual i have, or some combination of parameters
Buttons are: Single block, block delete, dry run, coolant, optional stop, magazine cw, mag. ccw, program reset, interdoor lock, Z lock, air blow, ..
i know what you mean, i have machine next to that one that has abs button, but this one doesnt have anything, whats more funny is that one friend has the same machine like this but a year or 2 older, everything is same, even parameters , i tryed to compare but nothing difrent, even with factor parameters its same lol
Need Help!- Rigid Tapping With the handle mode Osmanselim G-Code Programing 0 06-04-2009 04:29 PM
Problem- Incremental Vs Absolute mode chilly2k Mach Wizards, Macros, & Addons 4 03-06-2009 04:54 PM
0-MD Machine loses absolute coord with reset ILCORKILL Fanuc 6 02-25-2009 11:41 AM
What is - Torque Mode? Position Mode? Speed/Velocity Mode? sunmix Servo Motors and Drives 25 10-26-2008 03:53 AM
Using Mic Connectors For Xyz Cords luckeycnc CNC Plasma and Waterjet Machines 6 10-09-2006 01:24 PM
