I am having trouble tapping with a Fanuc OT C control, I have been getting a PS alarm 011 the book says no feed rate commanded. below I am putting in that block of code. it only a 4 flute 1/2 - 28 tap going in a .453" hole. here is the block from the program. I have a depth and a feed rate unless I need to format it differently? Thanks 47MLB T1010; GO Z0.200 M8; G0 XO.0; M29 S300; G99 G1 Z-0.570 F0.0357; G0 Z0.700 M9; M4 G1Z0.1; M5; ; |
Thanks for the help I tried the G84 in place of the G1 and got another error 205 Rigid mode DI signal off. the explanation from the book is [rigid mode DI signal is not ON when G84 (G74) is executed through the rigid M code (M29) is specified. consult the pmc ladder diagram to find the reason the DI signal (DGNG061.11) is not turned on.] I have a ladder list but did not see M29 or G84 listed? looks like I will have to get one of those tapping heads unless I can learn how to get past this? Thanks 47MLB |
What do you mean buy the option? I already bought the machine it has a 12 station turret with live tools and C axis. I thought it would be able to do what I am asking? This is still new to me so I am still learning isnt there a way to just turn on the option if one already owns the machine? This machine has been much more challenging than I had anticipated. But thanks for all the comments. |
| Option-something you have to pay extra for ![]() A lot of lathes, even with live tooling, can't rigid tap with the spindle. They can with a live tool, but since the chuck/part weight can vary so much, it makes it hard to tune the rigid tap on the main spindle. You need to check with the builder before you spin your wheels. |
| Thanks for the input. Now that I am waiting for the floating head to arrive is there a way to turn off sections or skip portions of the program. for example the one I posted now I want to run the program everything except for the tapping. I do not have an interface cable yet so I am entering everything by hand and single stepping untill I get it right. would say the G31 Skip function work? Thanks |
#10
| Skip signal (G31) is used for probing applications. You can use M99 Pnnn to jump to Nnnn: T0909 ... ... M01 M99 P102 (JUMP TO N102) T1010; G0 Z0.200 M8; G0 X0.0; M29 S300; G99 G1 Z-0.570 F0.0357; G0 Z0.700 M9; M4 G1Z0.1; M5; N102 (NEXT TOOL) T1111 ... ... |
#11
| T0909 ... ... M01 GOTO102 T1010; G0 Z0.200 M8; G0 X0.0; M29 S300; G99 G1 Z-0.570 F0.0357; G0 Z0.700 M9; M4 G1Z0.1; M5; N102 (NEXT TOOL) T1111 ... or turn on block skip and use this: T0909 ... ... M01 /T1010; /G0 Z0.200 M8; /G0 X0.0; /M29 S300; /G99 G1 Z-0.570 F0.0357; /G0 Z0.700 M9; /M4 G1Z0.1; /M5; N102 (NEXT TOOL) T1111 ... or a combination of both, only this has block skip turned off to skip the tapping: T0909 ... ... M01 /GOTO102 (or you can use M99 P102) T1010; G0 Z0.200 M8; G0 X0.0; M29 S300; G99 G1 Z-0.570 F0.0357; G0 Z0.700 M9; M4 G1Z0.1; M5; N102 (NEXT TOOL) T1111 ... As you can see, there are quite a few ways to do it...it just depends on machine options and personal preference. regards, Oz |
#12
Thanks I just tried the first option it skipped as intended but the block it skipped to the rpm went faster than anticipated into panic mode. Here is what it looks like below it is only a light thread in and out to give a diamond pattern about .020” deep. On the second example if I need to type the (goto102) I have not figured out how to type text on the control yet? And is the block skip the same as the block delete switch? Thanks again T0000; ; M01; M99 P102; T1010; G0 Z1.0 M8; G0 X0.0; Z0.05; M29 S560; G98 G84 Z-0.570 R-0.01 P50 F20.0; G80; G0 Z0.700 M9; G0 G28 X0.0; G0 G28 Z-3.0; ; N102; T10000; T1115; M4 S300; M8; G0 X1 Z0.02; G76 X0.88 F0.01; Z-0.6 F0.1; G0 X1.05; G0 G28 X0.0; G0 G28 Z-3.0; ; |
| Need Help!- Rigid Tapping G-Gode for Fanuc Pro 3 | need-a-day-off | G-Code Programing | 7 | 03-26-2010 02:25 PM |
| tapping on a mini mill without rigid tapping??? | mls | Haas Mills | 13 | 07-03-2009 06:43 PM |
| rigid tapping on miyano with fanuc 18i | terrywinstr | CNCzone Club House | 2 | 01-30-2009 04:33 AM |
| What exactly is Rigid tapping? Why people always ask does it do rigid tapping? | cjchands | General Metalwork Discussion | 23 | 12-19-2008 08:19 AM |
| Rigid tapping or tapping head | wildcat | Industrial Hobbies (Support forum) | 7 | 09-24-2006 12:08 PM |
