Old 02-10-2010, 10:32 PM
fasto is on a distinguished road
Fanuc triple servo drive troubles
Hi all, I've got a Hurco with the Fanuc AC triple servo drive amplifier, Fanuc# A06B-6050-H401, driving red cap motors. The drive's got some issues .
Immediately upon power-up, the "M" channel lights its TG led, which I have been told means some sort of fault with the encoder on the motor. Then, a few seconds later, the "M" channel OC light comes on (Overcurrent?). At this point, the drive's 200VAC contactors haven't been closed by the control, yet, so there's no DC bus voltage, and there can't possibly be a real overcurrent.
I first thought that I had bad encoder wiring or a bad encoder, but when exchanging the wiring at the drive between the "L" channel and the "M" channel the fault stays with the "M" channel.
I was told that shifting the S10M jumper would disable fault detection for the "M" channel. When I shift this jumper the drive doesn't show any fault LED's. I didn't try to run the machine with the "M" channel fault detection disabled.
I suspect there is some fault with the TTL logic on the drive. I spent a few hours today checking the encoder signal paths with my oscilloscope. All of the encoder outputs are working: there are "1","2","4","8" signals used by the drive, and A/B/Z/!A/!B/!Z signals which are used by the drive for faulty cable detection (I think..) and used by the control for positioning. I haven't determined anything conclusive, but I suspect that the fault detection logic is itself faulty!
I don't have the manual for the drive, supposedly Fanuc # B-54765E, though I am trying to get it from Fanuc. I can't imagine there is component level troubleshooting data in it, though.
If anyone has experience with this problem, or even with this drive, I'd like to hear from them. I have a thread going in the Hurco forum, but Fanuc equipment is unusual on Hurco machines so I wanted to put a post up here, too.
Thanks,
Aaron
Old 02-11-2010, 07:51 AM
Al_The_Man's Avatar
There is two small wires coming from the motor to the encoder plug for temperature sensor,
If these are open you can get an OC as the drive thinks the motor is overheated.
Old 02-12-2010, 01:19 PM
Thanks, I'll check that.
Fanuc Drive/Servo (A20B) Question Death Adder Fanuc 9 04-09-2008 09:42 AM
Troubles finding the right motor for the drive Progger Rutex Products 2 07-16-2007 08:28 AM
Can Viper 200 drive a Fanuc DC Servo Motor? maquiza Viper Servo drives 10 06-07-2007 09:56 PM
Fanuc 6050 Servo Drive thebighorn General Metal Working Machines 0 04-24-2007 01:05 PM
Belt drive troubles JFettig Benchtop Machines 17 03-26-2004 07:47 AM
