I recently had a servo alarm in my x axis that was traced to a broken wire on the encoder cable (Fanuc 3T controller on a Wasino LG-81) that fried my drive. Today I replaced the cards and got the machine going again. While it was down, I took apart both servo motors and cleaned out the dust from the brushes. This is a gang type lathe with just X and Z axis. Everything seems to be running ok except that all my dimensions in the x axis are off by about .040" It's as if the whole bed has moved .040" in the + direction. Or as if the machines new home position is off. I can adjust for it but wanted to ask what may have caused this? Any ideas? Thank you, Jeff |
| If the encoder was disturbed, then probably it is because the marker pulse position has changed, this can be corrected if you need to by the grid shift parameter, this adds or subtracts the home position in encoder counts. Al.
| Richmill "RICHMATE" 4th axis controller, manual | ken fedirko | General CNC (Mill and Lathe) Control Software (NC) | 3 | 01-03-2012 10:51 AM |
| Problem- G540 and the "A" axis jogs in the same direction regardless of arrow key pressed. | jerryrigge | Gecko Drives | 7 | 05-07-2009 02:02 PM |
| 5-Axis movment in "A" axis by hand | stevo1 | Fanuc | 1 | 09-04-2008 04:12 AM |
| ALARM!!! "Commanded X Axis move too far / Positive" | aimeahz | Bridgeport and Hardinge Mills | 6 | 04-20-2006 05:51 PM |
| Calculating "steps per unit" for rotary axis? | Beezer | Mach Software (ArtSoft software) | 2 | 11-28-2004 03:31 PM |
