Old 02-09-2010, 08:55 AM
cd0426 is on a distinguished road
Circular interpolation Fanuc O-M
Hello I need an example line of code to do a G03.
I have a Fanuc O-M controller.
I want to make a 1.25" circle with the with a .75" endmill.
Can not figure out how to calculate the I & J value or the order to put them in.
Thanks,
CD
Old 02-09-2010, 09:59 AM
beege's Avatar
beege is on a distinguished road
I and J are the distance in X and Y that the center point exists relative to the start point. For example, if you have a point at X.5 Y2. where a circle starts and the circle center is at X.75 Y2., your code would look like:
G01 X.5 Y2.
G03 X.5 Y2. I.25 J0
because the center point is .25 from the start point in X, and no distance from the start point in Y. Hope this is understandable.
I'm not giving you the answer for two reasons. First, the teach a man to fish thing, and second, I don't know where your circle exists on your coordinate system. Good Luck!
Old 02-09-2010, 11:09 AM
guru is on a distinguished road
I and J are the distance to center of the Arc in X and Y. Fanuc will read I and J as incremental distance.
So if you start your arc at 3 O'clock... "I" would be minus "J" would be 0(zero)
If you start your arc at 11 O'clock.."I" would be positive and "J" would be negative
Old 02-09-2010, 01:31 PM
Quick sample codes for you...
starting at 9 O'clock
(G41)G1X-1.0 Y0 F... (feed in to edge of circle)
G3 X-1.0 Y0 I1.0 J0 ( do full circle, X and Y end points can be left out)
(G40)G1 X-1.5 (move away)
Old 02-09-2010, 02:52 PM
BlueChip's Avatar
BlueChip is on a distinguished road
Circle Milling
Try this link :
http://www.kentechinc.com/tip7.html
Look for the free circle milling code generator on that page ... it will come in handy for ya.
Real World Machine Shop Software at ... www.KentechInc.com
Old 02-09-2010, 03:36 PM
CNCRim's Avatar
Let me jump in.
Is it must I J? If not you can alway just used simple R instead it's just work as good.
Old 02-09-2010, 04:20 PM
fanuc-support.c's Avatar
fanuc-support.c is on a distinguished road
CNCRIM is right just use R
I=the distance from the centre point of circle to the start in X with direction
J=the distance from the centre point of circle to the start in X with direction
Simple.
PM me and i'll send you a sheet explaining it all.
The Fanuc Support Center Team
www.fanuc-support.com
Old 02-09-2010, 10:05 PM
sinha_nsit is on a distinguished road
But, cannot make a complete circle with R method. The reason is that, for the same start and end points, infinite circles are possible, all with the same radius. In such a case, the circle would need to be made at least in two halves, if R method is desired to be used.
While both methods can be used, selection should generally be based on how dimensions are specified on the drawing.
Old 02-09-2010, 10:47 PM
CNCRim's Avatar
what are you talking about? if you want to make an arc more 180deg all you need is put a munis sign in from of the number like R-x.xxxx.
Will make complete 1" circle.
G1X0Y.5
G3Y.5R-.5
Old 02-10-2010, 02:16 AM
See the attached figure.
For the coincident start/end points, infinite circles are possible, all with the same radius. Possibly the machine would make one, which may or may not suit you.
File Type: pdf circles with coincident start and end points.pdf‎ (6.6 KB, 117 views)
  #11   Ban this user!
Old 02-10-2010, 03:51 AM
WRONG
Again i agree with CNCRim
  #12   Ban this user!
Old 02-10-2010, 05:06 AM
Have you looked at the figure posted by me?
It is not that a complete circle cannot be made. But the question is: which circle (see the figure)?
Newbie- Circular Interpolation Deadwood Mach Software (ArtSoft software) 3 01-11-2009 02:35 PM
circular interpolation sqatch Dolphin CADCAM 9 02-11-2008 12:02 AM
Circular or Helical Interpolation? meme General Metalwork Discussion 6 10-30-2007 03:05 AM
Circular interpolation problem L. Sakthivel Fanuc 3 10-17-2007 02:26 AM
No circular interpolation in G-Code? M30 Mastercam 2 07-24-2007 09:55 PM
