Old 02-09-2010, 01:20 AM
mroy0404 is on a distinguished road
Manual Guide i problems
Hello Guys
This is the first few days of playing around with this Fanuc 18i-TB control with EZ Guide i installed on it (same as Manual Guide i). I have created my first program an all seems good until it is simulated, the program runs until it reads the first sub program an gets to the G1456 at the end of sub then alarms out with a 078.
Could any of you fine gentle men help me with this problem??
Thanks Mike Roy in Canada
Old 02-09-2010, 05:06 AM
sinha_nsit is on a distinguished road
G1456?
Old 02-09-2010, 05:17 AM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
G1456 = Turning figure block END
Manual guide i
Don't know the reason though
post your program some one will be able to try it
I expect there are other parameters not set.
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
Old 02-09-2010, 05:22 AM
christinandavid's Avatar
christinandavid is on a distinguished road
i simulation
Is your sub pgm a free-form figure? If there is an error within the figure, the pgm will always alarm out at the last line/end of group, making the problem hard to pin-point.
Also beware of any macros that may cause the simulation to 'hang'
Try a dry-run and see if machine stops at same point.
DP
Old 02-09-2010, 11:42 AM
stevo1 is on a distinguished road
A couple of reasons is you are in background edit mode. Which I have never had a problem with so I doubt that. The other is it is searching for an address and not finding it. What does the program do when reading G1456? Better yet as Mystic has suggested post your code so we can look at it and try to spot what is wrong.
Stevo
Old 02-09-2010, 02:53 PM
ben_heinman is on a distinguished road
This may seem like a simple question but I'm going to ask anyway. Did you make sure that there is a sub-program?
Old 02-09-2010, 04:27 PM
fanuc-support.c's Avatar
fanuc-support.c is on a distinguished road
I like your thinking ben.
If the subprogram number specified with P is not found, P/S alarm No.
078 occurs.
Although i believe the EZ has a DATAU file, so that makes it a lottery.
The Fanuc Support Center Team
www.fanuc-support.com
Old 02-09-2010, 05:01 PM
The main program seems to run till it gets to M98 P11 (OD PROFILE) then it will read the entire subprogram until it gets to the end of the sub (0011) an gets to the second last line with the G1456; (last line is M99; ) this is where the cursor stops an sets out the alarm 078.
When I got this machine 2 months ago it had the EZ Guide turned off,(keep rely K10.5) was turned off making EZ guide not functional. There were afew other parameters that needed to be set as well. Maybe I did not get all the parameters set rite??
Any help would be great.
Old 02-09-2010, 06:11 PM
Alarm 078
I have attached pic's of the screen here
Name:	Alarm 078 001.jpg‎
ID:	99660   Click image for larger version
Name:	Alarm 078 002.jpg‎
ID:	99661   Click image for larger version
Name:	Alarm 078 003.jpg‎
ID:	99662   Click image for larger version
Name:	Alarm 078 004.jpg‎
Name:	Alarm 078 005.jpg‎
ID:	99664   Click image for larger version
Name:	Alarm 078 006.jpg‎
Old 02-09-2010, 06:25 PM
Like the perspective on the last shot.
Thought about photography for a living?
Can't you put your figure into the main pgm instead?
DP
  #11   Ban this user!
Old 02-09-2010, 06:28 PM
more pic's
Name:	Alarm 078 007.jpg‎
ID:	99666   Click image for larger version
Name:	Alarm 078 008.jpg‎
ID:	99667   Click image for larger version
Name:	Alarm 078 009.jpg‎
  #12   Ban this user!
Old 02-09-2010, 07:40 PM
I have just created this program (with no sub-programs) and get the same results, when the machine reads the program in simulation mode it alarms out at the line # 24 G1456; Alarm is still 078????
I have deleted line #24 G1456; an the program will cycle, however this can't be the rite way of programming.
Do any of you guys see any problems with this code???
Thanks for looking
Name:	Alarm 078 2 001.jpg‎
ID:	99676   Click image for larger version
Name:	Alarm 078 2 002.jpg‎
ID:	99677   Click image for larger version
Name:	Alarm 078 2 003.jpg‎
ID:	99678   Click image for larger version
Name:	Alarm 078 2 004.jpg‎
Opinion Manual Guide i CBNDude Fanuc 20 10-13-2010 12:02 PM
Fanuc 18i-TB with Manual Guide i problem mroy0404 Fanuc 8 03-21-2010 12:47 PM
Manual guide i? JDenyer232 Fanuc 3 11-07-2007 08:16 AM
manual guide vihgis_cnc General Metalwork Discussion 2 09-16-2005 01:22 PM
