Old 02-07-2010, 07:23 PM
Bruce Griffing is on a distinguished road
Need Fanuc Connectors for Upgrade
I have collected several Fanuc parts for the monitor and 4th axis upgrade I am planning for my Kitamura Mycenter 1. The machine has a Fanuc 0MC control. I have most of the cable connectors, but I am missing two that I have not been able to find. I do realize that I can go to the "CNC parts providers", and I will as a last resort. But I am initially trying to find these parts from a commercial source like Digikey or Mouser. To date I have had not luck with that. I was hoping that someone on the board has already done that.
First is the power connector for the 9" monochrome monitor presently on the machine.
I need the female connector of the pair shown above. The connector has a 5mm pitch - I could use the connector from a scrapped monitor if I could find one. Let me know if you have one.
The second connector is a power jumper connector for the servo amplifiers.
The power jumper appears to have 3.96mm pitch. I would appreciate any help or suggestions.
BTW, I found several of the other connectors I need surplus from ESI (electronic surplus inc). If interested search their site for Fanuc and/or Honda.
Old 02-07-2010, 09:00 PM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
The top one is (CP15)
Housing - JAPAN FCI SMS6PN-5
CONTACT - JAPAN FCI RC16M-23T3 or RC16M-SCT3
CABLE - J38 - (FPN: A02B-0120-K820)
The bottom one is (K3 & K7)
Tyco AMP Connector With
Receptacle Housing = 1-178128-3
Receptacle Contact = 1-175218-2
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
Old 02-07-2010, 09:23 PM
Mystic-
The connector you suggest is a 5.08mm pitch connector. When I measure mine, centerline to centerline across two spacings, I get 8mm. So I assumed the connector was 3.96mm since that is close to 4mm. Am I missing something? Otherwise the connectors you suggest seem to be right on. The keying diagram from Amp also has one three terminal shell with the correct key. I cannot find a similar "dynamic" connector with the correct(?) pitch. Suggestions?
Old 02-07-2010, 10:23 PM
I got the original information from an alpha i manual
This is the correct information from the alpha manual
It states the receptacle housing is actually
Receptacle Housing = 1-178288-3
** EDIT **
http://www.tycoelectronics.com/catal...174,438337&N=2
the 250V rated plugs are 3.81mm pitch
Name:	K5 Cable F0.JPG‎
Old 02-07-2010, 11:02 PM
Mystic-
Thanks a lot. Let me know if you know someone with a dead monitor. That first connector looks pretty rare - my chances for it are probably better with a scavenge. I could put a different connector on the supply, but I don't want to turn the machine into an orphan if I can avoid it.
Old 02-07-2010, 11:09 PM
give the guys at FCI a ring
Phone number for USA (Electronics Division)
+1 800 237 2374
I would be very surprised if this plug was unobtanium they still make replacement crts and alternative LCDs
Need Help!- How to Upgrade to Win XP on Fanuc 160i sigit Fanuc 0 01-22-2010 02:31 AM
Fanuc 3T Memory Upgrade? NID Fanuc 1 12-16-2009 01:04 PM
Fanuc OTa No Brackets - upgrade? barbter Fanuc 3 10-28-2007 10:42 AM
Fanuc O-M Software Upgrade Derek.C Fanuc 2 08-13-2007 10:17 PM
DB-25 Connectors Nmbmxer General Electronics Discussion 3 10-16-2005 07:05 PM
